Lock nut wrench
#494144
08/26/04 03:59 PM
Hey guys, I was wondering if anyone would know where I could find or would be interested in selling a Lock Nut Wrench (Part No. MB990954-01) and/or Hub Bolt Remover (Part No. MB991618-01). These tools are used to remove the front hubs and wheel stud on a Gen II montero. Thanks.
99 Montero, 3.5 L, Auto, Front/Rear Lockers, 2" Body Lift, 35's, 4.90's, Rock Sliders, Front/Rear Recievers
Re: Lock nut wrench
[Re: Marcus2113]
#494145
08/26/04 04:50 PM
I took the lockring with me to my local auto parts store, and matched it up with a 3/4t GM socket (GM one has 4 teeth). Bought it, brought it home and grinded off the two extra teeth on the socket. Works fine.
PHIL
Re: Lock nut wrench
[Re: PHIL_]
#494146
08/26/04 06:24 PM
Not required, no special tools are needed <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Lock nut wrench
[Re: Lloyd Swartz]
#494147
08/26/04 06:34 PM
Well if the lock nut wrench is not needed, how do you get the lock nut off the front to remove the rotors?
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
Re: Lock nut wrench
[Re: PHIL_]
#494148
08/26/04 06:34 PM
how much was the GM part that you bought?
Re: Lock nut wrench
[Re: Scottie2113]
#494149
08/26/04 08:32 PM
I had mine all apart, and didn't use ANY special tools...had to post about 20 times, but I got it done. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Lock nut wrench
[Re: Lloyd Swartz]
#494150
08/26/04 08:35 PM
Not required, no special tools are needed If you dont have the tool. How do you torque it down to spec when you go to put it together?
Re: Lock nut wrench
[Re: Tag]
#494151
08/26/04 08:39 PM
Are you talking about a wheel locknut? If so easiest way to get that thing off is a 3/4 socket or 12 point wrench and a sledgehammer <img src="/forums/images/graemlins/evil.gif" alt="" />
Re: Lock nut wrench
[Re: JunkIt]
#494152
08/26/04 09:53 PM
Are you talking about a wheel locknut? If so easiest way to get that thing off is a 3/4 socket or 12 point wrench and a sledgehammer <img src="/forums/images/graemlins/evil.gif" alt="" /> He's talking about the hub locknut. You can remove it by lightly tapping it with a screwdriver and hammer. It will come off easily enough. Technically you're supposed to tighten it to a specific torque amount though so this is where the wrench will come in handy however, I have seen many instances where this wasn't done w/out any harm but you need to take that w/ a grain of salt and make your own call. The chevy socket does work when ground down and has been noted on this and other forums.
Re: Lock nut wrench
[Re: off-roader]
#494153
08/27/04 01:25 AM
I will be working on this part of my Raider soon. Please show a pic of how you would use a screw driver to get it off. I have never dug into the hubs myself.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT gen 2 coils,Cranked front tbars Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
