Page 3 of 3 1 2 3
Re: Lock nut wrench [Re: MontyMcV] #494164 09/10/12 06:24 PM
TheViper Offline
You should (might?) be able to cut the pins off a Chevy one with a hack saw. Postage two ways to borrow will cost almost as much as the tool. I'll look at mine tonight and see if it has enough clearance between the pins to lay a blade in there.
ok, thanks
i wonder if this would work?
http://www.autozone.com/autozone/accesso...ier=110264_0_0_
and is one of these what you guys are talking about with the 3/4 ton locknut wrench
http://www.autozone.com/autozone/accesso...questid=2535705
http://www.autozone.com/autozone/accesso...questid=2536062
1995 Montero SR
Re: Lock nut wrench [Re: TheViper] #494165 09/10/12 07:20 PM
It'll probably be the 3rd one. The key is the diameter and unfortunately I don't recall it. I'll try to remember to measure it when I get home this evening. Feel free to remind me if I forget.
You can also buy a grinder, use it for this, then return it. Not something I would normally do simply because tools usually come in handy later down the line but then again, I have had to do it in a pinch when I visited an ex gf at her dorm and she needed help hanging something heavy in her room and I didn't have a drill/bits with me. Thank you HD. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Lock nut wrench [Re: TheViper] #494166 09/10/12 07:31 PM
Hard to say exactly from pics, as the opposing pins obviously need to be spaced right. The last one with six looks like what I bought. Every other thread here that I have read also used the six-pin as a start. i am sure I paid under $15 for mine, but that was over five years ago at least. There is a Toyota one that has two pins at hte right distance, but it is too shallow. It has to be a deep socket for ours.
Re: Lock nut wrench [Re: MontyMcV] #494167 09/10/12 08:04 PM
TheViper Offline
this one seems to be what you guys have recommended, so as long as i can saw 4 of the ends of i should be in good shape. Keep me posted if there is enough room to fit a blade
http://www.ebay.com/itm/Wilmar-W1270-4-W...#ht_1311wt_1159
1995 Montero SR
Re: Lock nut wrench [Re: TheViper] #494168 09/10/12 09:57 PM
You want the one for 3/4t ford or 3/4-1t GM, 6 point, hacksaw off 4 of the points, leaving two opposite points, use a file to smooth down th stubs, or just file off 4 of them. Also, a good 4" grinder is around $40, with a million uses. The K-D hub wrench is about $20 online. A hacksaw blade will fit.
The easiest way to take it loose is two pin punches in the nut holes and a lever. Forget torque settings. Take it off, replace the rotor, tighten the snot out of it to settle the bearing, back it all the way off, tighten just past where the wobble disappears and it starts to get tight, and you're done.
Re: Lock nut wrench [Re: fasteddy] #494169 09/11/12 12:20 AM
TheViper Offline
alright, great advice, thanks
i found a friend who has a grinder, so i just need to buy the tool
1995 Montero SR
Re: Lock nut wrench [Re: PHIL_] #494170 09/11/12 02:12 AM
plh Offline
I took the lockring with me to my local auto parts store, and matched it up with a 3/4t GM socket (GM one has 4 teeth). Bought it, brought it home and grinded off the two extra teeth on the socket. Works fine.
PHIL
I did this too. Had the tool from when I owned a few GM 4x4s. Sold the last one 24 years ago (a 1972 GMC 1/2 ton with Q78s) so I figured I wouldn't have a short term need for the GM tool :-)
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: Lock nut wrench [Re: plh] #494171 09/11/12 02:19 AM
TheViper Offline
PHIL
i thought about that, but im not doing it till this weekend and the prices at the local part store looked more expensive ($20) and they dont have it in stock, so i just bought the 6 prong one off of ebay...i hope this is the right one you guys are talking about
http://www.ebay.com/itm/230506922954?ssP...9#ht_500wt_1156
1995 Montero SR
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6340 MB (Peak: 0.7362 MB) Data Comp: Off Server Time: 2026-06-22 01:05:37 UTC
