Re: Flaring hard lines for Solid Axle Swap [Re: sweater] #494883 08/30/04 09:39 PM
hunterdan Offline
I would really really not recommend the compression fittings. I only see them as a temporary fix. A very iffy temporary fix. Do it right and get adapters, or buy long sections of tube and bend.
Dan
92 Rodeo, 3.1 TB crank, custom bumpstop spacers, DOR shackles, Flipped ball joints, D44 Rear, 4.56s and new magnaflow cat and dynomax ultraflow muffler Since been replaced by a 2 door Explorer on 31's shackles, cranked torsion bars and full exhaust
Re: Flaring hard lines for Solid Axle Swap [Re: hunterdan] #494884 08/30/04 09:50 PM
Ride Hard Offline OP
Actually, my father has an audi that he runs $4,000 porche brakes on, it uses AN compression fittings that were sent to him with the kit, from Germany.
Also, I dont think I should have too much of a problem running them on my truck, when thats what we run on an audi used in the pikes peak hill climb... <img src="/forums/images/graemlins/kewl.gif" alt="" />
'93 Rodeo - Dana 60 FF Rear - Dana 44 Front - 35's
Re: Flaring hard lines for Solid Axle Swap [Re: Ride Hard] #494885 08/31/04 01:10 AM
hunterdan Offline
Its a judgement call, but IMHO i would not trust them. A brake system is under high pressure and temperature. Its not that hard to flare the lines and add the appropriate fittings. The brakes are just a system I dont take short cuts on.
Dan
Re: Flaring hard lines for Solid Axle Swap [Re: hunterdan] #494886 08/31/04 09:31 PM
Thanks alot, guys... The brakes work amazing well... I cant belive the stopping power I now have... <img src="/forums/images/graemlins/shiner.gif" alt="" />
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6085 MB (Peak: 0.6647 MB) Data Comp: Off Server Time: 2026-11-16 08:41:19 UTC
