Warn Hubs$$
#494940
08/28/04 01:57 PM
I've struggled with the OE hubs long enough. There is nothing more frustrating than pulling a grade in the mountains and hearing the on again off again clunk clunk as the hubs go in and out. I've replace the hoses you name it, these hubs suck. I differ to the brain trust of this group and would like to know where is the best outlet for purchasing the Warn Manual hubs?
Mark Brown 2002 Sportage 2 Door Eibach lift,Coil Spring spacers, Body lift, K&N, 9.50x30 M/T
Re: Warn Hubs$$
[Re: brntrt]
#494941
08/28/04 02:25 PM
Kia Moderator Emeritus
Advance Auto Parts can get them in 2 - 3 business days for around $103 for a pair of hubs.
1998 Sportage - Gone. 2004 Honda Civic Coupe. 2007 Suzuki Grand Vitara - She got it.
Re: Warn Hubs$$
[Re: Axe Man]
#494942
08/28/04 02:29 PM
Carquest in Seattle was able to source some overnight, no place in Chicago has heard of imports and nothing comes faster than 2-3 days. Depends on your area I guess, Durango ought to have some place that has some on hand. Isn't that the 4-Wheel capital of the world (Oh wait, that's Silverton huh? LOL)
*Edit - You shall not be disappointed with the Warns my good man, I love mine!
Chris
Re: Warn Hubs$$
[Re: Axe Man]
#494943
08/29/04 01:11 PM
Thanks Axe I'll check them out!
Re: Warn Hubs$$
[Re: brntrt]
#494944
09/08/04 01:35 PM
A couple of questions: 1. What is the Warn Hub Part Number ?
2. Are they fairly easy to replace?
3. Are there any special tools or pullers needed to get the original vacuum hubs off and Warn hubs on.
4. What do you do with the old vacuum hoses & connections.
Thanks, Hank
Sportage, 1998, 4X4, 5 spd, Factory Config., vacuum hubs, 4 door, 100K miles Weekender-1975 Bricklin, 351CI, auto, Gull Wing, 13K miles
Re: Warn Hubs$$
[Re: fishman]
#494945
09/08/04 02:22 PM
The 95-01 Sportage Automatic mechanical hublock kit is Warn part number 61918.
60247 is for manual hub.
Re: Warn Hubs$$
[Re: Lou]
#494946
09/08/04 02:50 PM
Ooh! What about the '02 Sportage? No automatic mechanical hub-lock kit?
02 [color:"red"] Sportie [/color] 5sp 4x4 2dr. 1?" Body + 4" Rocksportgear lifts, 31x10.50 Wildcats M/Ts, Manual Hubs, Yakima rack, basket. Redline gear oils http://www.cardomain.com/id/calapooyasMy beater, 03 Land Rover Freelander SE3
Re: Warn Hubs$$
[Re: Calappoyas]
#494947
09/08/04 04:46 PM
I think the listing in the Warn catalog - that I copied as is - has not been updated and simply shows as when they last reviewed their catalog.
The automatic mechanical works very very well but - to my judgnemnt - should be restricted to mild environment or mild usage. It will not stand abuse. If you do mud and other hard stuff, take the manuals.
Re: Warn Hubs$$
[Re: brntrt]
#494948
09/08/04 08:02 PM
do the auto mechanicals work like the vacs did, because i found them still for sale and im gonna jump on em if theyre worth it
Re: Warn Hubs$$
#494949
09/08/04 08:18 PM
I had a '96 and the auto hubs worked fine until the day I really got stuck and they failed. They failed me many a time so I since got the manuals and I'm a lot happier. Believe me, if you don't want to get stranded or not knowing when they will fail, get the manuals. That way you know they are working.
1985 Toyota 4x4 4Runner. 1989 Suzuki Sidekick 4x4.
