Re: Packing bearings...how?
#495070
08/30/04 04:13 AM
Muffler bearings go out quite a bit and need servicing... might want to search for those also... <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
1986 Toyota 4x4 22wEBer Ported EB Offroad H/O Head "Josh Cam" Ported Intake & Weber38mm Carb LCE Header & 2.25in Exhaust RB 1" BL, RS5000, SAW Tbars
2011 FJ Cruiser - SOLD
[Re: VAHunter17]
#495071
08/30/04 04:49 AM
Damn... Y'all are harsh over here! <img src="/forums/images/graemlins/lol.gif" alt="" />
4xGeek (Chris) '97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc... No longer stuck in SoCal!!
[Re: ArbitraryNotion]
#495072
08/30/04 04:49 AM
Don't forget to check your blinker fluid, also! <img src="/forums/images/graemlins/pfft.gif" alt="" /> Yeah, a glob of high-temp grease in your clean palm and whack, scrape, turn, repeat...
#495073
08/30/04 05:22 AM
raise vehicle, tire off, hub off, 2 lock nuts and a spacer and a lock washer, may wanna take brake caliper off if you wanna remove the rotor, pack bearing put it back together good luck dave You forgot two things: 1. If you want to pack both front wheel bearings (and who would only do the outboard bearing) you need to get a new inner seal and you have to take the caliper off!!! 2. Clean the bearing in a solvent cleaner before re-packing!!!!
"Serenity through Sobriety"
#495074
08/30/04 09:25 PM
<img src="/forums/images/graemlins/butwiggle.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
'98 Tacoma TRD ext.cab 2.7 5spd 6inFabtech sus w/ 33x12.5.15 TrxusSTS on 15x10 DC-1 (Black)
'90 4Runner 3.0auto stock as of now
