Re: More 87 Trooper mystery... #495180 09/02/04 11:57 PM
lttlbddy Offline
The GM 10-bolt was only used in Rodeos.
The 10-bolt or 12-bolt refers to the number of bolts holding the ring gear onto the carrier.
Steve G
Re: More 87 Trooper mystery... [Re: lttlbddy] #495181 09/03/04 12:21 AM
Smiley Offline
For clarity:
The number of bolts that are used to describe a differential are located on the INSIDE, where you can't see them. --- It has nothing to do with how many bolts are on the cover.
Also:
When you see the term 'Third member', it means that there is no dif cover at all... The differential comes apart from the other side, and it has a solid face where a dif cover would usually be located. --- With a Third Member, the ring, carrier, and pinion are all mounted together on a single removable unit, and it all comes out from the opposite side.
HTH!
Cheers! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Smiley
Six Isuzus, so far... still have three of them.
Re: More 87 Trooper mystery... [Re: Smiley] #495182 09/03/04 01:10 AM
lttlbddy Offline
For more clarification - this here is an Isuzu 10-bolt with Tera 5.38s and an ARB installed. The arrows point to 3 of the 10 bolts that hold the ring gear in place.
Steve G
PS I'll leave the 1000 words to Smiley, I like pictures!!
Re: More 87 Trooper mystery... [Re: lttlbddy] #495183 09/03/04 02:04 AM
Ahh ok thanks for the info and nice pic! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: More 87 Trooper mystery... [Re: lttlbddy] #495184 09/03/04 06:05 PM
paulevans76 Offline
Steve G
so maybe they used it during the transition? Or maybe someone who owned his rig before him swapped one in after some breakage or an accident? I mean, you gotta get a rear, you don't see any troopers at the junkyard, you see an isuzu rodeo, grab that rear, all bolts up, bada-bing.
Eh, who knows.
Paul
88 Troop - Posing yard art
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6113 MB (Peak: 0.6729 MB) Data Comp: Off Server Time: 2026-11-17 06:13:36 UTC
