Re: Average MPG??? #496078 09/04/04 05:04 AM
My question is what kind of axle ratio are some of these guys running. Dont some of the jeeps come with a 4 popper I would think they would be get better mileage but I can except the lesser mileage just as long as getting the ponies.
Re: Average MPG??? #496079 09/04/04 07:29 AM
(were talking wrangler here just FYI) usually the 4.0's come with 3.73 unless its an auto, or a rubi (rubi's are 4.10), and the 2.5's come with 4.10's. with how bad the aerodynmics of jeeps are it takes alot out of the 2.5 to make it go down the road at the same speed as a 4.0. so while your running your 4.0 1/4-1/2 to go 75 the 2.5 is somthing like 3/4 throttle, so you don't gain much on the highway. around town is better than a 4.0's but... around town driving isn't usually high milage.
Re: Average MPG??? [Re: 5spd] #496080 09/14/04 03:03 AM
All you lookers with xjs post up or is that it?? <img src="/forums/images/graemlins/drunk.gif" alt="" />
Better late than never: I came across a 90 XJ last March; 17 mpg, but now 22 to 25 mpg depending on highway grades. I ran the following, which is basicly a 90,000 mile maintenance schedule;
Tuned it up,replaced radiator hoses, flushed system, adapted an auxilorary fan switch, lubricated chassis components, new oxygen sensor, new EGR, Changed rear and front diff fluids, changed transfer case and trannie fluids, added an Optima yellow top battery and upgraded my electrical system to run 100 amps (it came with a 150 amp alternator), changed fuel filter, replaced CCV and added a "burp cup" to catch blowby, cleaned crankcase cover inside and out, cleaned TBI, ran a ground from TPS to body. I plan to lift it and gear up to 4.10 in the future, so this mpg will change somewhat. <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5931 MB (Peak: 0.6466 MB) Data Comp: Off Server Time: 2026-06-09 23:19:22 UTC
