2wd & 4wd differences #496379 09/01/04 01:30 AM
dildinon Offline OP
other that the extra hole in the tunnel for the transfer case shifter, are there any physical differences between 3rd gen 2wd and 4wd cabs? how about beds? thx.
Davin Nisser
'94 Pickup Xtra Cab Deluxe 3.0 V6 5spd...'84 lwb frame swap with 2" body/drive train lift and solid axle in the works...
Re: 2wd & 4wd differences [Re: dildinon] #496380 09/01/04 02:40 AM
Adam F Offline
I know the flare of the fenders is much less on 2wd trucks. More than likely stock 31" tires would rub on a 2wd body.
97 4R, stock, daily driver
Re: 2wd & 4wd differences [Re: dildinon] #496381 09/01/04 02:48 AM
rednekbean Offline
i know of a difference in the fender flare, 4wd bigger and wider to alow the bigger tire(duh, yes i know). i know of a few lowrider id-jits that swapped in the 4wd beds so they could tuck a bigger set of rims and lower the truck more.
i dont know of any thing else
nick
92' Pick-up, SAS, gears to make her crawl, 37's , bullet proof motor, and alot of time invested.
06 CRF450R one mean roost flinging machine
Re: 2wd & 4wd differences [Re: rednekbean] #496382 09/01/04 03:07 AM
ArbitraryNotion Offline
Very little is different other than the suspension.
Here is a lifted 2wd and a 4wd. Just looking at them, you can hardly see the difference.
1986 Toyota 4x4 22wEBer
Ported EB Offroad H/O Head "Josh Cam"
Ported Intake & Weber38mm Carb
LCE Header & 2.25in Exhaust
RB 1" BL, RS5000, SAW Tbars
2011 FJ Cruiser - SOLD
Re: 2wd & 4wd differences [Re: dildinon] #496383 09/01/04 03:20 PM
fourwd1 Offline
Don't know about 3rd gen, but on 1st and 2nd they're the same except for the fender flare at the wheel opening as stated above, and the hole for the t-case shifter. Everything else is the same and interchangeable.
1st and 2 gen beds also have the same mounting bolt pattern.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: 2wd & 4wd differences [Re: ArbitraryNotion] #496384 09/01/04 09:49 PM
Terrys_85_Toy Offline
Hey ArbitraryNotion, how did you lift the front of the 2wd?
1985 Toyota Pickup
5.29's
Rear Spool
Dual Cases
35" BFG MTs
Re: 2wd & 4wd differences [Re: Terrys_85_Toy] #496385 09/01/04 10:15 PM
kyle-22r Offline
i think he cranked the torsion bars, and the rest is from a body lift
'91 4x4 shortbed
22R-E, W56, the dd!
Re: 2wd & 4wd differences [Re: kyle-22r] #496386 09/01/04 11:26 PM
Its a fabtech 3.5in lift kit, 2in RB body lift, 33x15x12.5in tires and 4wd shocks. Its also got 4.30 gears. 2wd trannies aren't geared like 4wd so 4.30 matches 33's.
Josh
Re: 2wd & 4wd differences [Re: dildinon] #496387 09/02/04 01:48 AM
Snowtoy Offline
The difference between the 2wd and 4wd third gen(84-88) trucks are bigger wider front fenders, different bumper end caps, and the bed wheel wells are also wider/more square on the 4x4's, everything else is the same. You can use the 2wd fenders and beds on 4x's if you cut the fenders and run a set of bushwacker fender flares.
Re: 2wd & 4wd differences [Re: Snowtoy] #496388 09/02/04 06:05 AM
dildinon Offline OP
third gens are 89-95
Davin Nisser
PHP: 7.4.33 Page Time: 2.788s Queries: 16 (0.003s) Memory: 0.6375 MB (Peak: 0.7602 MB) Data Comp: Off Server Time: 2026-06-07 10:05:50 UTC
