2wd 1ton rearends #496887 09/02/04 06:03 AM
dildinon Offline OP
i know the duallies have full floating rears but do the non duallies? and are the axle housings any different from a regular 4wd rear?
Davin Nisser
'94 Pickup Xtra Cab Deluxe 3.0 V6 5spd...'84 lwb frame swap with 2" body/drive train lift and solid axle in the works...
Re: 2wd 1ton rearends [Re: dildinon] #496888 09/02/04 06:15 AM
kyle-22r Offline
1 ton non duallies have semi floating axles. they have the same third member as a 4x4(8") and 30 spline axles, but they're 5 lug and 56" wide. '79-85 4x4s are 55" wide, and '86-95 4x4s are 58" wide
also, 2wd are sprung-under, 4wd are sprung-over
'91 4x4 shortbed
22R-E, W56, the dd!
Re: 2wd 1ton rearends [Re: kyle-22r] #496889 09/02/04 11:13 PM
4
4RnrRick Offline
No the non-dually 1 ton rear ends are not full floaters.
Here I post I put together about the 2wd vs 4wd rear axles & diffs.
http://www.pirate4x4.com/forum/showthread.php?s=&postid=1876052#post1876052
Project Quasimodo
'85 Xtra Cab (2wd, 22RTE, Auto => 4wd, 3RZ, w56, 2.28x4.70)
Re: 2wd 1ton rearends [Re: 4RnrRick] #496890 09/03/04 04:05 PM
Vonka Offline
Thanks 4RnrRick for your toyota 1-ton information.I luck out on owning a 86 2WD G282 rearend.Lots of torque with stock tires 195/75 x 14" rims.
88 4x4 22re
86 2wd 1-ton 22re
91 2wd 22re
Re: 2wd 1ton rearends [Re: 4RnrRick] #496891 09/03/04 07:29 PM
dildinon Offline OP
thanks for the link.
Davin Nisser
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6047 MB (Peak: 0.6687 MB) Data Comp: Off Server Time: 2026-06-07 07:51:00 UTC
