Re: My jeep transmission [Re: carnuck] #499025 09/11/04 06:28 AM
since its older than 94 it should be the 42RE or whatever the new tranny is. they stopped using the AW4 in 94 or ZJ's with the 4.0
Re: My jeep transmission #499026 09/17/04 01:31 PM
Well, I had my jeep worked on yesterday. The problem was a solenoid, governor pressure failed. They used:
Gasket OI 21004003
Transduce 21030410
Solenoid 8059043
Oil Autom 1081018
Solvent
Also, the DRB III test found an oxygen sensor was faulty. So they replaced the
Sensor OX 8037155
All of this cost my $50 - the warranty deductable - and the jeep runs fine.
Re: My jeep transmission #499027 09/17/04 05:28 PM
carnuck Offline
That would be the solenoid on the valve body. It causes all sorts of weirdness when it goes bad. They probably also drilled the valve body to enlarge the one return hole that clogs up while they were at it. (whole process takes about 3 hours)
Build your truck the head men say, but it must be built in such a way...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5930 MB (Peak: 0.6454 MB) Data Comp: Off Server Time: 2026-06-07 06:51:03 UTC
