Page 2 of 3 1 2 3
Re: Well i tried to remove my Molding [Re: Creeper] #499082 09/09/04 12:27 PM
urso8up Offline OP
thanks guys for all your help. I got some sticker remover last night but i didn't get to try it because i got my new tires put on my T and didn't get home until late. But i will try it tonight
1998 T100 4x4 3 body lift 4 procomp suspension 15x10 steel wheels and 35x12.50x15 Baja Claws
http://www.cardomain.com/id/urso8up
Re: Well i tried to remove my Molding [Re: urso8up] #499083 09/10/04 02:04 AM
I did the thumb thing....jacked it up....I also used goo gone...it worked...It just takes time....My paints a little jacked now...Im going to have both sides re painted...OUCH... <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Well i tried to remove my Molding #499084 09/10/04 02:49 AM
urso8up Offline OP
well i tried it again tonightI used bug and Tar remover and a sticker stickey remover I found at the store. Man does it take a while to do what a pain but it is all worth it.
Re: Well i tried to remove my Molding #499085 09/10/04 03:31 PM
Honger Offline
zero and urso,
Are you sure you jacked your paint so bad that a good progressive polish won't fix it? White, Black, and a few of the other colors of Toyota don't have clearcoat, so you can polish bad scuffs, swirls, oxidation, etc. out. Much cheaper and less drastic.
Regards,
Joel
1998 Toyota T100 SR5 ExtraCab 4WD
Re: Well i tried to remove my Molding [Re: Honger] #499086 09/10/04 08:25 PM
4
4xGeek Offline
My black has a clearcoat... <img src="/forums/images/graemlins/confused.gif" alt="" />
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
Re: Well i tried to remove my Molding [Re: 4xGeek] #499087 09/10/04 09:13 PM
Honger Offline
Must not be factory paint then...
Black, White, Red, Yellow... these colors are non-clearcoat paint. Now, if it is a metallic version then it will have one. All metallics have clearcoat.
(EDIT)As well, I'm talking base colors. If you have Black #202, you should not have clearcoat. That is unless it is Toyoguard stuff from the South/Southeast.
Re: Well i tried to remove my Molding [Re: Honger] #499088 09/10/04 09:30 PM
4
4xGeek Offline
Got me confused enough to call & check... You're right; Dealer installed option (also available in CA), put on by the PO. <img src="/forums/images/graemlins/kewl.gif" alt="" />
4xGeek (Chris)
Re: Well i tried to remove my Molding [Re: 4xGeek] #499089 09/10/04 10:13 PM
Honger Offline
I believe the Toyoguard is available everywhere, some regions just automatically put it on. I was pretty sure I was right about that. <img src="/forums/images/graemlins/cheers.gif" alt="" /> You had me worried for a second though!
Re: Well i tried to remove my Molding [Re: Honger] #499090 09/21/04 01:55 PM
urso8up Offline OP
all the molding ids off and it looks great i ended up getting a eraser for my drill and using that it works wonders i also used it on the pinstripe and it worked awesome.
Re: Well i tried to remove my Molding [Re: urso8up] #499091 09/21/04 03:58 PM
rmg Offline
urso8up,
will you post some pics??? I've started mine but haven't had much time to work on it. I found the hair dryer really takes the extra sticky off well. Then I followed up with some 3m sticker remover. I can barely see the difference in the paint under the molding.
Also what are you talking about an eraser? Care to explain??
Ryan
95 T100 2WD ExtCab
All Stock
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6380 MB (Peak: 0.7447 MB) Data Comp: Off Server Time: 2026-06-07 02:16:31 UTC
