help needing to find a brake sqeek... #499414 09/09/04 03:37 AM
G
gentouteg Offline OP
well, each time let go of the brakes, i would get a loud sqeek from the drivers rear drums. sounds like a peice of metal scraping. it only happens when there is weight on it. when i jack up the truck and try to step on the brake then let go, it won't make the noise. but as soon as you drop it and have weight on it, it'll make the annoying sqeek again. by the way, it's 95 t100. any help would be great. thanks.
Re: help needing to find a brake sqeek... [Re: gentouteg] #499415 09/09/04 12:53 PM
A
averkam Offline
Axle bearings in good shape? Kind of grasping at sraws because I am not looking at the truck.
2000 Ext Cab SR5 4WD 2.7L 5-speed.
Re: help needing to find a brake sqeek... [Re: gentouteg] #499416 09/09/04 01:58 PM
G
GeriatricToy Offline
Take a look at your LSPV (load sensing proportional valve) located on the passender side rear just behind the drum. Make sure it's not restricted and if need be, bleed it. This valve often times gets missed when a brake job is done. It's the last one done on a brake bleed so there's no real need to do the others.
2000 Tacoma SR5 - Bone stock 'cept a little bling.
2000 Tacoma SR5 - Bone stock.
Re: help needing to find a brake sqeek... [Re: gentouteg] #499417 09/09/04 02:29 PM
OOP'S Offline
There are contact points on the backing plates where the brake shoes touch. Make sure there is a small amount of grease on these points. These are metal to metal points and will squeak. Also a small amount of grease on all of the pivot points helps. Use a very thin coat of grease. <img src="/forums/images/graemlins/kewl.gif" alt="" />
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6012 MB (Peak: 0.6565 MB) Data Comp: Off Server Time: 2026-06-10 17:38:29 UTC
