Page 2 of 3 1 2 3
Re: GEN II sway bar removal for wheeling? [Re: TeaQue] #499834 09/11/04 06:51 PM
TeaQue Offline OP
can someone just confirm how much of a pain it is to remove the front sway bar? if it only takes 30 minutes to yank off then it wouldn't be a big deal to me to take it off for the trail and then put it back on afterwards.
I might hit up a trail about 30 minutes from here with my friends tacoma on 33's.
All i have are 31's so i'm gonna need all the help i can get
<img src="/forums/images/graemlins/lol.gif" alt="" />
1997 Montero LS
3.5 V6
31x10.5 BFG A/T's
T-bar lift
Optima Yellow Top
Cheap Pilot Fog lights
Re: GEN II sway bar removal for wheeling? [Re: TeaQue] #499835 09/12/04 05:38 AM
bretwalda Offline
The rear removal is questionable - the front - dont do it - especially on a Gen2 3.5, your brush guard on the front, you're asking for trouble. There's a whole lot more handling issues at stake. Edit: I see you wanna just unbolt for a ride - easy enough. Although the link between the bar and lower arm on mine was so rusted I had to cut mine off with a grinder - I'd make sure I can get it off before I head out and attempt it on the trail.
Misterbishi has in the works a batch of front sway disconnects but they are a long time coming <img src="/forums/images/graemlins/sleeping.gif" alt="" />. I have one of his early prototypes and it works great - and is the only way to deal with the front end IMO.
As far as the rear - you will get a ton more drop articulation - at least on the Gen 2. I cant even get my rear wheels off the ground unless I max out my 48" hilift to near-dangerous heights <img src="/forums/images/graemlins/ignore.gif" alt="" /> (and before anyone flames me please realize there's never a reason for me to not just jack on the rear axle - I'm just illustrating a point <img src="/forums/images/graemlins/wink.gif" alt="" />)
Pic of the front disconnected:
Rear sway removed:
concreteprinter.com
Re: GEN II sway bar removal for wheeling? [Re: bretwalda] #499836 09/12/04 07:59 AM
TeaQue Offline OP
Rear sway removed:
when you say theres more than handling issues at stake.....what are you talking about? <img src="/forums/images/graemlins/confused.gif" alt="" />
are there other mods i should do first before taking off the sway bars?
anymore pics you want to post? <img src="/forums/images/graemlins/kewl.gif" alt="" />
preferably flex pics??? <img src="/forums/images/graemlins/notooth.gif" alt="" />
1997 Montero LS
3.5 V6
31x10.5 BFG A/T's
T-bar lift
Optima Yellow Top
Re: GEN II sway bar removal for wheeling? [Re: TeaQue] #499837 09/12/04 04:08 PM
Tag Offline
Also cant it damage the shocks by overextending them?
I somewhere along the line want one of the things Bretwalda has on his front swaybar. What happened to the guy that had the air powered one? I think it was on the rear though.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
Re: GEN II sway bar removal for wheeling? [Re: TeaQue] #499838 09/12/04 11:29 PM
socalmonty Offline
I have a Gen1 and removed both sway bars. To be honest, I didn't notice much of a difference on or off-road.
Sean - Orange County, CA
MAIL: seanwilliams78@gmail.com
1995 Montero SR - For exploring and getting away!
1994 Volvo 850 Turbo - 402hp and counting!
1966 VW Bug 2275cc - For stoplight drags!
Re: GEN II sway bar removal for wheeling? [Re: socalmonty] #499839 09/29/04 09:45 PM
TeaQue Offline OP
bump, in case anyone wants to speak more on this subject.
Bretwalda said something about there being too much risk, especially with my front brush guard---just for removing the front.
can you please elaborate more? i joined the 4wd club at my college and we are going to Disney, OK for a trip next month. I want to know what exactly you meant by that comment before I take off the front sway bar for the trip.
1997 Montero LS
3.5 V6
31x10.5 BFG A/T's
T-bar lift
Optima Yellow Top
Re: GEN II sway bar removal for wheeling? [Re: TeaQue] #499840 09/29/04 10:42 PM
Teaque,
There's not much to say on this subject. Many have removed their rears and left their fronts on because their rigs are also daily drivers.
Until you try it yourself, it's almost no use asking how the rig will handle, etc. If you do try it, be sure to check just how much articulation you gain (measure it) and also keep in mind by removing it your suspension will be more complaint which may be another result you're after.
Myself I run w/out the rear sway bar. I used to run a set of quick disconnects for the rear but that ended in Moab 3 years ago when I pretzel'd the bar on a rock.
Since then, I've been w/out the rear bar but then again, I don't try to drive anywhere near as fast as a car when going on curves and am always drive alert to what's going on around me. That's no guaranty that nothing will happen but it's a "calculated risk" I'm willing to take.
Wheel back spacing... I should also point out that in most cases, tire sizes are increased when this is done and there have been substancial discussion as to whether the increase in height versus the increase in width raises the COG which is directly related to how safe the rig will be with the sway bars removed.
As was pointed out... [disclaimer on]There is a risk and liability involved for anyone who removes them so just bear that in mind if you remove yours.[disclaimer off]<img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: GEN II sway bar removal for wheeling? [Re: off-roader] #499841 09/29/04 11:12 PM
TeaQue Offline OP
Thanks for the reply. I guess I was just more or less wondering what he meant by me being more at risk because I have a brush guard <img src="/forums/images/graemlins/confused.gif" alt="" />
anyone know if i will over extend the shocks on the rear on a Gen II for sure?
they are stock shocks....
1997 Montero LS
3.5 V6
31x10.5 BFG A/T's
T-bar lift
Optima Yellow Top
Re: GEN II sway bar removal for wheeling? [Re: TeaQue] #499842 09/30/04 03:45 AM
BobShaw Offline
I would think that you would not overextend the shocks. The swaybar does not keep both wheels from dropping together the same distance.
The Gen I front (did not have a rear?) needs to be removed completely or it will bang against the lower A arm and the steering linkage, if just loosened. I would definintly advise wheels with a smaller rear offset to move the tires outboard for more stabililty. Yes it can be squirley on the highway at high speeds W/O the swaybar.
4WD's are built not bought.
Bob Shaw
Re: GEN II sway bar removal for wheeling? [Re: BobShaw] #499843 09/30/04 07:12 AM
Bob, unlike the leaf sprung I-4's the coil sprung v6's have a rear anti-sway bar.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.008s) Memory: 0.6498 MB (Peak: 0.7632 MB) Data Comp: Off Server Time: 2026-11-17 11:18:55 UTC
