Re: 85 pick up won't start [Re: Roland2655] #501761 09/14/04 07:24 PM
4Crawler Offline
I haven't actually talk to him yet, but the owner told me that they aren't getting any power to the fuel pump.
When is he measureing for power at the pump? In stock mode, its only present while starting or with the engine actually running. With the jumper I mentioned, it'll come on any time the ignition is on, engine running or not.
Re: 85 pick up won't start [Re: 4Crawler] #501762 09/14/04 08:34 PM
Roland2655 Offline OP
thanks Roger, I'll make sure he is aware of the jumper and give you an update later today or first thing tomorrow. Appreciate all the help.........
ridge runner
Re: 85 pick up won't start [Re: Roland2655] #501763 09/15/04 05:39 PM
Just got the word its the fuel pump <img src="/forums/images/graemlins/frown.gif" alt="" /> not sure what they put in there a couple of years ago but it only lasted about 8k miles. Can you get one that mounts externally? This is getting old and I really don't want to go through this again <img src="/forums/images/graemlins/angry.gif" alt="" /> Also I'm guessing that OEM is better than Bosch, or does it really make that much difference?
ridge runner
Re: 85 pick up won't start [Re: Roland2655] #501764 09/15/04 05:48 PM
G
GeriatricToy Offline
I've replaced mine twice over the years and the last time I replaced it, I cut an access door right over the fuel pump. I've dropped the tank for fuel pump replacement and to do some frame welding and the last time my fuel pump went, I refused to drop the tank again and decided to put the door in. The trap door also alows for easy cleaning of that concaved area where the fuel pump sits.
2000 Tacoma SR5 - Bone stock 'cept a little bling.
2000 Tacoma SR5 - Bone stock.
Re: 85 pick up won't start [Re: GeriatricToy] #501765 09/15/04 05:52 PM
I thought about suggesting that but god only knows what the cost would be to have the shop do that. Did you go OEM or Bosch?
ridge runner
Re: 85 pick up won't start [Re: Roland2655] #501766 09/16/04 12:42 PM
G
The last one I put in was from a local foreign auto parts place and I don't recall the brand name. I remember it was made in Japan but that means about nothing. Lately, If $$ warrent it, I but OEM.
Re: 85 pick up won't start [Re: GeriatricToy] #501767 09/16/04 05:32 PM
4Crawler Offline
Whatever you do, do not replace the original starter unless its completely worn out. The Denso starter will last many 100's of thousands of miles and only need periodic replacement of the copper solenoid contacts. It is so easy and inexpensive to replace them and the reliability (or lack thereof) of a typical parts-store "rebuilt" starter is so variable that you are far better off fixing what came on the engine instead of replacing it.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6268 MB (Peak: 0.7177 MB) Data Comp: Off Server Time: 2026-06-17 03:06:32 UTC
