unusual heat / gauges show fine (we're gonna be a rolling teaky torch)!! #501827 09/14/04 06:36 PM
joelle Offline OP
Radiator - 1 yr
water pump 1 1/2 yr
thermo 1mo
hoses are fairly new
with all these replacements you'd think it would be running where it should be. Gauges all read well within range
Granted, we're here in Phx AZ, but everytime I get out of the truck, I feel all this heat emitting from the engine compartment and I know this is not normal
I am worried about it melting our new hoses! some bucks there! (one of em was $106.00)!
Could this be a gauge problem?
Other problems - the spark plugs were replaced 1 yr ago and they're covered in ash buildup, has no acceleration, doesn't seem to want to kick down to pass (spankin new tranny)
and I think it is time to rebuild the throttle bodies - I smell gas.
It hates Arco gas and loves Chevron or Mobile gas.
One extra little thing - the rear anti-loc light keeps coming on! @#$&*$!
It's a 1990 3.slow / automatic
"Sh*t or get off the pott"!
1990 4x4RNR 3.slo auto P.O.S.
"The silver bullet"! NOT!
Re: unusual heat / gauges show fine (we're gonna be a rolling teaky torch)!! [Re: joelle] #501828 09/15/04 01:03 AM
DRTDEVL Offline
The kickdown cable needs to be adjusted... That's first on the list. If that don't fix 'er right up, check to see if you have a brake dragging...
The throttle body has nothing to do with the fuel smell... That is a sign of running rich, or the engine is just working too danged hard for some reason.
If those two don't work, check the codes (although some would say this is first, I tend to lean more towards the "I know better than a computer," schooled by experience book). Figger out why the plugs have deposits... Could they have developed when the rig sat forever???
Let us know...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5905 MB (Peak: 0.6388 MB) Data Comp: Off Server Time: 2026-06-17 15:48:48 UTC
