other cars with the 3.0 mitsu engines? need parts. #502171 09/15/04 04:38 PM
jamesn Offline OP
my buddy just bought a raider with the 3.0v6. it was a front hit and the owner said that it had running problems before it was hit. i am looking for spare parts like the dist, fuel injectors, ecu, sensors, radiator, brackets, a/c condensor, throttle body, ect. i was checking ebay and found this ad fot a gasket set that fits a bunch of cars that have this engine. can i rob parts off of a hyundai? go all the way to the bottom of this page, they are spaced out from the copy and paste. thanks. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />This auction is for (1) Full Gasket Set
All major gaskets appear to be present (see pictures)
This Full Gasket Set fits the following engine(s):
Chrysler Car
3.0L 181.1 (2972cc) SOHC V6 (12 Valve) (Mitsubishi Eng.) 1988-96
Dodge Truck
3.0L 181.1 (2972cc) SOHC V6 (12 Valve) (Mitsubishi Eng.) 1987-98
see below, its long.
Hyundai Car
3.0L 2972cc SOHC V6 (12Valve) (Mitsubishi Eng.) 1990-97
Mitsubishi Car
3.0L 2555cc SOHC V6 (12 Valve) 1988-91
Mitsubishi Truck
3.0L 1972cc SOHC V6 (12 Valve) 1989-95
Re: other cars with the 3.0 mitsu engines? need parts. [Re: jamesn] #502172 09/15/04 07:44 PM
pmontero Offline
James,
I should have most of what you're looking for in my basement. Look in the Parts for Sale section and search on "blowout" and you'll find my posting. PM me with a list and I'll get back to you on price and availability.
Powell
'87 Montero Diesel
'98 Porsche Boxster Electric
and more...
Greasology
NotPetroleum
Re: other cars with the 3.0 mitsu engines? need parts. [Re: pmontero] #502173 09/15/04 07:46 PM
pmontero Offline
I also have a complete engine pulled from a running '89 Montero with 130k on it. It's for sale with the engine stand it's sitting on. PM me if you want it.
Powell
'87 Montero Diesel
and more...
Greasology
NotPetroleum
Re: other cars with the 3.0 mitsu engines? need parts. [Re: pmontero] #502174 09/16/04 02:32 AM
jamesn Offline OP
thanks guy, but i have $375 credit with the local j-yard from a load of scrap i brought in. i need to use it up.
Re: other cars with the 3.0 mitsu engines? need parts. [Re: jamesn] #502175 09/22/04 02:31 AM
KrzyDav Offline
The Hyundia sonata and Mitsu Diamate SOHC 12 valve models are front wheel drive but have the same block as the conventional rear wheel drive mont. , unlike all the FWD Chry products.
All the Gasket sets I've bought will be for the Caravan/Lebaron setup.
The plenum and manild gasket set will have to come from CarQuest or NAPA seperately. About 22.$$ a set.
Some of the tubes from the waterpump will have different O rings, but the others are in some sets. The EGR gasket won't be there but an individual felpro is avail. If you get it cheap enough it will be worth it . The Head and Exhaust gaskets bought sperately will run you around $100 alone.
dave h.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6070 MB (Peak: 0.6725 MB) Data Comp: Off Server Time: 2026-11-16 08:33:25 UTC
