Re: u-bolt flip/shackle question
[Re: Yaker]
#503342
09/20/04 07:04 AM
I think the shock mounts end up in the same general location, however, since the spring plate is now on top of the axle instead of below, they end up maybe 5" higher than they were before, so your old shocks may end up being too long.
[Re: 4Crawler]
#503343
09/20/04 03:52 PM
So if I'm running 2 inch blocks I'm looking at 7 inch shorter shocks. If there not to long this could be a good thing because <img src="/forums/images/graemlins/kewl.gif" alt="" /> my shocks are limiting my rear travel a few inches anway. Any other problems you could think of?
Work smart not hard!
83 SR5 Pickup, 4" home brew lift, 36 inch TSLs ,locked front and rear, 4.7 t-case gears, 5.71 diff. gears, cross over high steer, 8k warn, custom bumper and flat bed, and huge plans.
[Re: Yaker]
#503344
09/20/04 05:48 PM
With the lift blocks, you'll be unlikely to be able to re-use the 2WD u-bolts, so you'll need to source new ones. You can actually buy u-bolt flip kits for about the same cost as a set of u-bolts and some even include shock mounts.
In fact I should have my old flipped u-bolts/spring plates/shock mounts for sale once I get the new axle stuffed under my truck. The u-bolts might just be long enough to handle a lift block.
[Re: 4Crawler]
#503345
09/20/04 07:21 PM
I'm sure I would be intrested in those. Witch new axle are you putting under there? I hope to have something done with my rears to do a way with those blocks. The axle wrap is killing me. It causes my U-bolts to come lose over some time.
[Re: Yaker]
#503346
10/08/04 03:15 AM
quick newbie question, what is axle wrap?
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/ Camper/33x10.5BFG-AT/Open 4:88/1.5"BJS/ +2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
[Re: allochris]
#503347
10/08/04 05:38 AM
It is the tendency of the torque applied to the axle while accelerating to twist the springs as they resist the torque. Spring over axle is more prone to wrap since you have a greater moment arm from the center line of the axle than to the spring pack (i.e. the differential is farther away from the frame than the spring are). Adding blocks compounds the problem by separating the axle from the springs farther.
You can actually see it happening, get behind or beside a truck while it is pulling away from a stop light. Watch the rear half of the leaf spring pack twist downward. Stock springs with the heavy overload leaf on the bottom will show this the best, you'll see the overload leaf go way down in back until the tall spring clamp attached to it catches on the top of the main leaf. That serves as an anti-wrap device on the stock springs. One reason not to remove it in an attempt to get more travel out of the rear springs. You will get more travel for a while, until the first hard climb, then your springs will end up in the shape of an "S", the front half will be arched upwards, the rear half downwards. Saw it happen once, took just a few seconds of bad wheel hop to trash the springs. Wheel hop is a side effect of axle wrap, axle winds up against the springs, then if the tire loses traction, it slips, unloads the axle and thus the spring, the wheels hop into the air from the springs unloading, then when the weight is back on the wheels, the wrapping starts again until something lets go.
