turning radius toy vs d44 #504179 09/21/04 03:51 AM
dildinon Offline OP
ive been reading posts here and on pirate about toy/d44 hybrids. everyone agrees the 44 gives a tighter turning radius, but nobody mentions how much tighter. turning radius is dependent on wheelbase so i guess my question is actually what turning angles will the knuckles allow?
Davin Nisser
'94 Pickup Xtra Cab Deluxe 3.0 V6 5spd...'84 lwb frame swap with 2" body/drive train lift and solid axle in the works...
Re: turning radius toy vs d44 [Re: dildinon] #504180 09/21/04 04:40 PM
ErikB Offline
Toyota Moderator
I think the Spicer manual I have advertises that the D44 has a 40 degree turning radius. I don't know how that compares to a straight axle Toy or IFS, but my 44 turns quite a bit sharper than my IFS did even though the wheel base is a few inches longer. Its nice on the trail and in the parking lot. <img src="/forums/images/graemlins/smile.gif" alt="" />
http://home.4x4wire.com/erik
Re: turning radius toy vs d44 [Re: ErikB] #504181 09/21/04 05:02 PM
4Crawler Offline
Stock steering angle on the Toyota solid axle is 30 degrees.. I think most folks turn that down a bit to preserve their birfields.
On my front axle, with stock width and 33x9.50 tires, I had to run a 1/4" spacer to keep the tires off the springs at full lock. Now with the D60 outers, and the axle 3" wider, I still need to run 1/4" spacers to keep the tires off the springs. So that means I can cut the wheels in 1.5" farther than before. In fact I wish I would have shortened up the steering arms just a little more, as there is a bit of steering travel I can't quite use. I can usually turn at least as sharp as a shorter wheelbase Jeep on the trail.
Re: turning radius toy vs d44 [Re: 4Crawler] #504182 09/21/04 10:18 PM
dildinon Offline OP
thanks guys that was exactly the info i was looking for.
Davin Nisser
PHP: 7.4.33 Page Time: 0.098s Queries: 15 (0.004s) Memory: 0.6022 MB (Peak: 0.6586 MB) Data Comp: Off Server Time: 2026-06-12 08:53:18 UTC
