Page 6 of 8 1 2 3 4 5 6 7 8
Re: ARB front lockers ***Urgent update*** [Re: wd8cdh] #505246 10/23/04 10:35 PM
Dave Scott Offline
gary, give me five to ten minutes to post in the other thread and then decide if you're still interested in this line of manufacture.
Re: ARB front lockers ***Urgent update*** [Re: logansportage] #505247 10/27/04 12:07 PM
DamKia Offline OP
Kia Moderator
Hi logansportage,
Look here: Diff. Drawing
I am most interested in dimension G, C1, B and F but other dimensions would be helpfull too.
Thanks
All right guys, sorry for the delay, but here are the measurements from my stock non-LSD differential. It is from a 1998 4x4 KIA Sportage with 28 spline axles.
A = 6.225" (outer diameter of the ring gear mounting surface)
B = 4.650" (inner diameter of the ring gear mounting surface)
C1 = 1.555" (outer diameter of the axle shaft housing/bearing seat)
C2 = 1.555" (outer diameter of the axle shaft housing/bearing seat)
D1 = 1.175" (inner diameter of the axle shaft housing)
D2 = 1.175" (inner diameter of the axle shaft housing)
E1 = 0.810" (bearing seat width)
E2 = 0.810" (bearing seat width)
F = 0.900" (thickness of ring gear mounting surface to bearing seat)
G = 4.450" (distance from bearing seat E1 to bearing seat E2)
*H1 = 2.350" (distance from outer bearing seat edge E1 to where axle shaft would stop)
*H1 = 2.350" (distance from outer bearing seat edge E2 to where axle shaft would stop)
*H1a = 1.155" (distance from snap ring location to where axle shaft would stop) I.e. Spline length inside side gear
*H2a = 1.155" (distance from snap ring location to where axle shaft would stop) I.e. Spline length inside side gear
*Axle spline count = 28
*Axle shaft diameter = TBM (To Be Measured)
*Axle spline length = TBM ( To Be Measured)
Updates as of 5:47 PM Mountain Standard Time 10/21/2004
I will try and update this post with the distance from the outer edge of the bearing seat to the end of the dotted lines in the picture posted in wd8cdh's post listed above. I believe this is the distance from the outer edge of the bearing seat to the end of the axel shaft which is also the inner most side of the differential side gear.
From Bitsamissin (Outerlimits Mitsubishi guru)
Front Mitsubishi 28 spline
Ok measurements as follows :-
A = 176.0mm 6.928"
B = 124.0mm 4.882"
C1 = 45.3mm 1.783"
C2 = 45.3mm
D1 = 32.0mm 1.260"
D2 = 32.0mm
E1 = 19.5mm 0.768"
E2 = 19.5mm
F = 20.5mm 0.807"
G = 113.0mm 4.449"
No of crownwheel bolts = 10
PCD crownwheel bolt holes = 150.0mm
Hope this helps.
Re: ARB front lockers ***UPDATES?*** [Re: DamKia] #505248 12/03/04 07:44 PM
MorganEstill Offline
Any updates regarding ARB?
'97 Sportage, 4" Lift 1" BL, 31" BAJA CLAWS, Rallye 4000s, Line-Xed Hood, Grille, K&N, 2.25" Exhaust, RS9000s, GPS...
"What is IFS and where can I get some??" (outerlimits4x4.com)
Re: ARB front lockers ***UPDATES?*** [Re: MorganEstill] #505249 12/16/04 04:57 AM
DSHornet Offline
For any guys who are interested in what Suzuki gearheads might do to help, check out these URL's:
http://bbs.zuwharrie.com/yabbse/index.php
http://www.zukiworld.com/
Paw-paw Don, y'all
Favorite quote: "One need never apologize for exercising the Golden Rule."
Re: ARB front lockers ***UPDATES?*** [Re: MorganEstill] #505250 01/06/05 06:11 AM
DamKia Offline OP
Kia Moderator
Private msg from Daniel Bongard:
G'day Gary,
It's an impressive thread you've started here.
Unfortunately I have to report that with the exception of your email asking if we've made any decisions on the Kia applications there have been no other enquiries to my email address and nothing forwarded to me from our sales team.
That is not to say that it will not happen...only to say that the priority positioning of its development puts it well behind the vocal majority of drivers of Toyota's, Nissan's, Mitsubishi's, and even Mazda's and Daihatsu's.
If you can in fact confirm any cross-over applications (I noted that someone was considering a possible cross over with a late Chevy model) then that would help.
All good things to those who wait I guess.
Best regards and Happy New Year!
-daniel
Please find Daniels' email addy at the head of this thread and GIVE HIM AN EMAIL!!!!!, otherwise all chances of ANY locker, front or rear, is gone.
FOR GOOD!
At this point we cannot afford to be choosy about which end we do first.............
Re: ARB front lockers ***UPDATES?*** [Re: DamKia] #505251 01/07/05 08:05 PM
I e-mailed him. <img src="/forums/images/graemlins/confused.gif" alt="" /> Wonder what the hell happened?... While I am more likely at the moment to just go ahead and convert the rear to a Dana 35 with a No Slip locker and a leaf spring conversion, I will write another e-mail to send to him.
Re: ARB front lockers ***UPDATES?*** [Re: MorganEstill] #505252 01/09/05 10:03 AM
Calappoyas Offline
I emailed the US Sales team at the Seattle office. I got a letter back saying "thanks for you interest in ARB; here's our catalog" ah well <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
02 [color:"red"] Sportie [/color] 5sp 4x4 2dr. 1?" Body + 4" Rocksportgear lifts, 31x10.50 Wildcats M/Ts, Manual Hubs, Yakima rack, basket. Redline gear oils
http://www.cardomain.com/id/calapooyas
My beater, 03 Land Rover Freelander SE3
Re: ARB front lockers ***UPDATES?*** [Re: Calappoyas] #505253 01/10/05 02:40 PM
Dave Scott Offline
did that 5 years ago, got the exact same response.
Re: ARB front lockers ***UPDATES?*** [Re: Dave Scott] #505254 01/10/05 06:32 PM
I didn't even get a stupid catalog. <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/drunk.gif" alt="" />
Is it the ARB Corp. in AU we need to contact?
Re: ARB front lockers ***UPDATES?*** [Re: MorganEstill] #505255 01/10/05 10:46 PM
shifter26 Offline
already e-mailed them awhile back .. they replied with the same answer .. but i did not get any catalog neither .. and no info for the lockers..
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6511 MB (Peak: 0.7586 MB) Data Comp: Off Server Time: 2026-06-17 10:48:36 UTC
