custom kingpin d44? #505714 09/24/04 06:54 AM
dildinon Offline OP
from what ive been reading here and on pirate, the only advantage a d44 has over a toy axle other than width is the tighter turning radius. strengthwise they seem to be a wash except that when a u-joint fails in a d44 it can (often?) damage the ball joints in the knuckle, making the vehicle unsteerable. would it be possible to modify a d44 knuckles to kingpin style using stock toyota or d60 (or any other kingpin knuckles?) hardware? thx.
Davin Nisser
'94 Pickup Xtra Cab Deluxe 3.0 V6 5spd...'84 lwb frame swap with 2" body/drive train lift and solid axle in the works...
Re: custom kingpin d44? [Re: dildinon] #505715 09/24/04 07:26 AM
4Crawler Offline
Re: custom kingpin d44? [Re: 4Crawler] #505716 09/24/04 07:51 AM
kyle-22r Offline
there are kingpin 44s, i believe some are even open knuckle(i'm thinking early 70s f150s?)
'91 4x4 shortbed
22R-E, W56, the dd!
Re: custom kingpin d44? [Re: 4Crawler] #505717 09/24/04 08:47 AM
dildinon Offline OP
expense mostly. its ~$1000 for just the bare knuckles. i figure i could pick up a 44 and modify the knuckles for half that. almost every part ive looked at for 60s costs more than 44s and i dont think ill need the extra strength running 33s or 35s. im looking into running a toy/d44 hybrid but itll be on my dd so the balljoints possibly fubaring my frontend worries me a little. a toy/d60 would be nice <img src="/forums/images/graemlins/smile.gif" alt="" />but thats a little out of my price range <img src="/forums/images/graemlins/frown.gif" alt="" />.
Davin Nisser
Re: custom kingpin d44? [Re: dildinon] #505718 09/24/04 02:44 PM
ZUK Offline
doesn't AllPro have a nice hybrid axle?
mostly stock
Re: custom kingpin d44? [Re: ZUK] #505719 09/24/04 03:15 PM
OOP'S Offline
Yes a very nice one. Welder Bilt in Rancho Cordova, CA will also build you one to your specs.
A-P
Are you tired of breaking and replacing Birfield joints? Looking for a knuckle joint that will hold up to serious trail use? Now you can upgrade to the strength of Dana 60 U-joints. We attach huge Ford F-450 bearings, U-joints, and hubs. These are combined with one ton hubs, custom Wilwood brakes & rotors. These axle assemblies are setup to use stock Toyota 15" wheels (6 lug) and Toyota third members. Axle measures 62" wide. Ideal for use with wider IFS style 1986 and later rear axles. All new Ford F-450 parts are used to build our axles. Custom designed Wilwood brakes, rotors, and spindle allow commonly used after market 15" wheels with 6 bolt pattern3rd member not included. Uses any Toyota 8" 3rd member.
Above axle pictured with optional Diff Armor
See axle assembly instructions here
The D60/Toyota axle now includes Hy-SteerÖ crossover steering. We have also upgraded the axles and now provide chromoly inner axles on all units. Complete axle with Hy-SteerÖ $4,399
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: custom kingpin d44? [Re: dildinon] #505720 09/24/04 07:49 PM
dildinon Offline OP
back to my original question:
Davin Nisser
Re: custom kingpin d44? [Re: dildinon] #505721 09/24/04 09:29 PM
John Smith Offline
While I do not have an answer for you to your question I must ask one of my own.
Why do you want to do this? What do you find wrong with a regular Toyota 8" axle? If you want to go Dana why not just get a waggy axle like everyone else and be done with it? I just don't see the point of the hybrid you want to build.
You state you are only going to run 33s or 35s, either a regular dana 44 or toyota 8 will be plenty strong for your purpose.
John Smith 79 FJ40
87 StdCab w/22R TLCA# 9074
Re: custom kingpin d44? [Re: dildinon] #505722 09/24/04 09:56 PM
4Crawler Offline
Sure, anything is possible. Either look for an existing king pin D44 (as noted above), see if there are kits available (search with Google or other web search engine). If not, design your own kit, assuming you have a milling machine and tooling, should be no problem knocking one out <img src="/forums/images/graemlins/smile.gif" alt="" /> If you've got to pay a machinist to do the work, you may find the existing solutions are quite reasonable priced. Maybe call up Currie Enterprises and see what they have to offer.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6321 MB (Peak: 0.7367 MB) Data Comp: Off Server Time: 2026-06-13 01:33:28 UTC
