Re: Gas leak
[Re: ttreat]
#505882
10/04/04 02:57 PM
they should be steel not copper.
Scott Landon 1995 T100 - total buildup underway 1988 4Runner (22RE, W56) - new DD 2005 Dodge CTD 4x4 - Tow Beast 1990 Spec Miata 2010 GT3 2013 E92 M3
Re: Gas leak
[Re: letmrun]
#505883
08/04/05 03:15 PM
I seem to have the same sort of problem... gas is leaking from somewhere, and I'm going to need to drop the tank to figure out where.
Does anything need to be depressurized before I start disconnecting the lines to the tank?
96 Toyota T100 4x4 Ext Cab 88 Toyota Pickup 4x4 (For Sale-- $1600) 01 Honda S2000 00 Honda Odyssey (wife's)
Re: Gas leak
[Re: teamking]
#505884
08/04/05 03:39 PM
The only pressure in the tank will be relieved when you take the gas cap off. There is pressure in the fuel rail but that is held by the fuel pressure regulator and shouldn't effect the tank.
1997 T-100 4X4 Xcab,Warn Hubs 02 Camry LE 2008 Yaris
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.5979 MB (Peak: 0.6673 MB) Data Comp: Off Server Time: 2026-06-19 12:00:00 UTCValid HTML 5 and Valid CSS
