Transmission Swap Musings
#506293
09/26/04 03:37 PM
The transmission died in my 94 Trooper. I'll have another post detailing that, but it appears that the pump died, and it overheated. So, I've been digging through old posts reading what I can. This is what I've come up with: The 4L60E will bolt up to the engine, and there is an adaptor available (slightly custom, but only $300) to mate that to the Isuzu transfer case. (See link #1 below) The problem with this swap is that the 4L60E is computer controlled, and I don't think that there is any chance that the Isuzu TCM will control it. The 4L60 is it's older (less sophisticated brother). This was used in ~93 in the 3.4l Camaro. This is a 4-speed transmission with a low 1st gear, and a high overdrive (0.7:1). It also has a lockup torque converter which I could just install a switch for to use on the highway. This transmission requires a cable connected to the throttle. The 700R4 is essentially the 4L60, but without the lockup torque converter. Again, this requires a cable connected to the throttle. Jerry Lemond suggested the 700R4 from a 2.8L S10 pickup. He confirmed what I've read: that the adaptor that will fit the 4L60 will fit the 700R4. I'm keeping the Isuzu transfer case because the vehicle speed sensor is on the back of it. I also happen to like the flange type outputs, and I shouldn't have to do much if anything to the shifter. So, $300 for an adaptor, $50? 100? for the 4wd output shaft for the transmission (or if I find a 4wd tranny, that part is already done). Crossmembers and a shifter linkage + dipstick and it's done. Driveline length should also be the same (according to the measurements that I can find online). Jerry said that the flex plate should fit the GM torque converters, and once I pull my dead transmission I'm going to go to the parts stores and confirm that by comparing my torque converter to one for a 93 S10. What have I missed? -Tad 1a) http://community.webshots.com/photo/191748056/128784741FRZjAR1b) http://community.webshots.com/photo/128784757/128784757LffQNm
1994 Trooper. 3.2 DOHC/auto. 4.77s,3xARB, OME 919HD springs. 34" Swamper LTBs 2001 Trooper "stock" <img src="/forums/images/graemlins/wink.gif" alt="" /> http://www.planetisuzoo.com
Re: Transmission Swap Musings
[Re: Nazrat]
#506294
09/26/04 04:14 PM
ITs always been my understanding that the 4L60E is a 90 degree bolt pattern for the 90 degree series motors. I was not aware that there was an adapter for these motors and the trans. I did know that they put the 700R4 behind some 2.8s in the s-10s. These would probably be a direct bolt in, except for maybe the starter. I think the cost involved here would be approaching the cost of a new/rebuilt 4L30E. The 4L60E would be a great tranny to have, but is considerably overkill for these motors. Id like to see you prove all this wrong and install this thing with no problem. Before I go too far, I would definitely do a ton of research. I would try and find the 700R4 from the 2.8. Maybe find out what it would take and cost to convert to a lock of Torque converter.
Dan
92 Rodeo, 3.1 TB crank, custom bumpstop spacers, DOR shackles, Flipped ball joints, D44 Rear, 4.56s and new magnaflow cat and dynomax ultraflow muffler Since been replaced by a 2 door Explorer on 31's shackles, cranked torsion bars and full exhaust
[Re: Nazrat]
#506295
09/26/04 05:35 PM
The 4L60 is a good tranny, and it is definitely the simplest of the bunch. The 4L60's simple highway lockup gets the nod for me over the 700R4.
Don't sweat the vehicle speed sensor -- there are cable-inline units available that will work fine, or fully electronic units to fit pretty much whatever you swap. For a little extra dinero, you can go with a programmable blackbox and be able to dial out tire size and gear changes, if they happen. That said, if you like the transfer case, keep it... it will make driveshafts and crossmembers that much easier. Also, Tera gears have crept down in price, IIRC.
Be sure to budget 33-50% of your budget for the unexpected. It sucks to get partway through and not be able to finish due to cash! BTDT... If you do start with a 2WD tranny and need to install a 4WD output shaft, that's gonna require a pretty full tear-down of the tranny.
Randii
[Re: randii]
#506296
09/26/04 05:56 PM
I'm actually thinking of going on a junkyard trip to look for a 4L60 - working or not it will give me the part's needed to check for things like torque converter fitment, starter-bellhousing clearance, etc. The speed sensor was mentioned because at this point, if I can't keep the transfer-case (and the before mentioned speed sensor) then I'll put in another 4L30E - that is the line that makes this swap not worthwhile at this point. The engine will run just fine with the TCM disconnected, and if I can keep the t-case and install a 4L60 - and the throttle cable/TCC switch I won't have to touch the 3.2l engine wiring. I'm looking at swapping because in as much as it can make sense for a driveline to have a fuse, having a $2,000 fuse that can't be purchased at an auto parts store in the middle of nowhere (after towing the truck out of the woods) isn't a good thing. With the stock 3.2, I'm not worried about destroying a 700R4 or 4L60. Maybe I should just install another 4l30e and learn to drive slower, but even at 55mph the trucks pass me I plan on budgeting 2x the expected amount for this swap, with the expectation that I could very easily have to spend another $1k getting the transmission rebuilt if I go used. That's one reason why I'd like to find one out of a 2.8l 4x4 Blazer or S10: low horsepower and low weight, compared to what this tranny is rated at. -Tad
[Re: Nazrat]
#506297
09/26/04 07:27 PM
Isuzu Moderator
The biggest problem with using the 4L60 is the offset transmission pan. The Isuzu t-case doesn't quite have the reach to easily clear the pan. I'm not saying it won't clear, but you may need to clock the t-case a little and/or cut the corner out of the tranny pan to fit a driveshaft by it. Here's what I mean: ![[Linked Image]](http://www.houlster.com/amigo/caddy/images/111-1160_img.jpg) The TOD case, I think, may have a little bit more reach so it clears the pan better. Another option is to use a 2-piece front driveshaft with a carrier bearing. This leads to a very short front piece of the shaft, but with IFS it doesn't matter since the diff doesn't move. For tranny control you have a couple options. There's always the manual valve body option. This will work with the newer 4L60-E's with the removable bell housing as well. On the 4L60-E, it removes the electronics and makes it full-manual shifting. Just like a manual tranny, but no clutch. You would still wire in a switch for the torque converter lockup. Another problem. There are 2 different types of 4L60 tranny bodies. The earlier versions all had 1-piece bodies. The bell is built in. Starting in '96, they used a 2-piece w/ removable bell housing (see the pic above). This 2-piece also has a different, 6-bolt tail housing pattern. The older style has a 4-bolt pattern. This adapter that you mentioned: will not work with the 1-piece tranny housing. It is a 6-bolt hex pattern adapter that will bolt only to the later 2-piece housing. If you want to do this with existing parts, you need: 2-piece 4L60-E transmission ('96 and later). 60 deg V-6 pattern bell housing for it ('96 and later 3.8 camaro/firebird) "small" torque converter (same camaro/firebird) The adapter plate shown above. Tranny control (either a spendy, near $1000 aftermarket controller or a full manual valve-body) And likely a 2-piece front driveshaft to clear the pan. Another option is to use a Dana 300 transfer case. With this you can use: A 1-piece TH700/4L60 from an S-10 (no electronics other than TC lockup) Existing TH700 - Dana 300 adapter ($300 - $400 I think. Ask Dallas). torque converter from S-10 as well. Custom or aftermarket shifter setup for D300 (twinstick is a worthy option) This t-case will clear the tranny pan and give you a 2.6: ratio stock. You can also get 2 Dana 44 pinion flanges from 1st gen Rodeo's (~$40), or 2nd gen Rodeo/Amigo (~$60) and they will bolt right on to the front and rear output shafts of the Dana 300. This will give you the Zu flanges you want. All you need to do is lengthen/shorten the driveshafts as needed. ![[Linked Image]](http://www.houlster.com/amigo/drivetrain/images/114_1485_small.jpg) And if that isn't enough, you still have the A340 options as well. See my old post Oh no, jeep parts!!I'm still working on the AW4 to 60 deg bell housing matchup. The bell is about $350 new from Isuzu, and I haven't worked out the flexplate & torque converter issues (whether stock parts will work or if custom ones are needed). I'm still looking, but there may be a cheaper bell used on the late-80's Cherokee that bolted to the 4-cyl motor at that time that had the same 60 deg bell housing pattern. (This is the same pattern you need for the 3.2/3.5 BTW). There is an adapter for this tranny to the Zu t-case as well from the '03 and up Isuzu's. This will let the Zu t-case bolt up to the AW4, but I'm not sure on spline counts. If the '03 Zu tranny is 27 spline (like the previous Zu autos and t-cases), the Zu case should bolt right up. If not, it'll take some more work to do, involving a spacer plate and conversion shaft. --Dan
[Re: Nazrat]
#506298
09/26/04 08:25 PM
Isuzu Moderator
I'm actually thinking of going on a junkyard trip to look for a 4L60 - working or not it will give me the part's needed to check for things like torque converter fitment, starter-bellhousing clearance, etc. The main thing to keep in mind is there are a few different diameters of torque converters. A stock converter from a 4.3 or SBC will not fit the smaller 60 deg bell housing. I don't know if the bolt pattern on the converter is the same between sizes or not. Keep that in mind when you're measureing. I've got a converter from a '98 4.3 S-10. I can take some measurements if you want, but again, it's too big for the 60 deg bell. The speed sensor was mentioned because at this point, if I can't keep the transfer-case (and the before mentioned speed sensor) then I'll put in another 4L30E - that is the line that makes this swap not worthwhile at this point.
I guess I just don't understand this. You're letting the entire swap hinge on a speed sensor? That is a minor issue and should be among the least of your worries when you're talking about a tranny / driveline swap. There are much larger fish to fry doing this kind of work. If you can pull off the rest of the swap, the sensor issue will be easy to figure out. There are a multitude of signal converters out there that should work for you if the signal needs to be modified. The Dana 300 (if you go that route) is not exactly a rare t-case swap. Plenty of folks use it with EFI motors that need a speed sensor input. It's a problem that's already been solved, you just need to pick the one that's right for you. --Dan
[Re: houlster]
#506299
09/26/04 10:53 PM
I guess I just don't understand this. You're letting the entire swap hinge on a speed sensor? That is a minor issue and should be among the least of your worries when you're talking about a tranny / driveline swap. There are much larger fish to fry doing this kind of work. If you can pull off the rest of the swap, the sensor issue will be easy to figure out. There are a multitude of signal converters out there that should work for you if the signal needs to be modified. The Dana 300 (if you go that route) is not exactly a rare t-case swap. Plenty of folks use it with EFI motors that need a speed sensor input. It's a problem that's already been solved, you just need to pick the one that's right for you. --Dan It's more of if I have to go that far, it probably isn't worth it for me. I don't think that I'm generally very hard on things. I may be jinxing myself here, but I run 33s and lockers and haven't ever broken a tie-rod adjuster or CV. I mean yes, I can get a dana 300 and a 4L60 and some flanges from an early Rodeo D44, but then I need to start over with driveshafts, shifters, crossmembers, exhaust, and then the speed sensor issue. So, lets assume that I can find a transmission for $400. Maybe even at our pick-n-pull $20 rate if I'm lucky (and at that rate I'd better buy 3 and hope to get one good one). A used dana 300 is going to be what, $100? 200? The dana 300 to 4l60 kit from Novak is $525. - that includes a speed sensor and tone ring. The speed sensor box that *should* let me use that speed sensor with the Isuzu ecu/speedometer is going to be around $100. - this is the big experiment Then two dana 44 flanges for $40 each, and two shortened driveshafts for $100 each. Twin stick shifter: $100 (if I have to buy a shifter, I might as well get the twin) We are now pushing $1500 to $2000. Then it's back to making crossmembers, skid plates and linkages. That cost though is certainly more appealing than spending $2500 to have this transmission rebuilt. (That's the number on the receipt that I inherited from the previous owner - a mere 50k miles ago). Maybe if I can start finding some deals on some of these things this can become a reality. I'm almost worried now that I'll find a deal on another 4L30E... -Tad
[Re: Nazrat]
#506300
09/27/04 04:05 AM
88 Pickup,4x4, 2.6 L, AMC head, K&N Air filter, Aisin Hubs, Redline Oils everywhere, 94 Trooper wheels.
[Re: jdobbsj]
#506301
09/27/04 05:13 AM
Dont remember on the 60* 700s, but the ones that I have ahd in the past were all lock-up comverter...
As a matter of fact, there is a prewiered kit avail for tehm to pout in non comp contro;;ed cars/trucks....
HTH Chase
Chase
[Re: chasespeed]
#506302
09/27/04 11:34 PM
Do you have your heart set on an auto. tranny? How about a Toyota 5-speed manual? It sounds like it's more work than you're interested in doing, but here's the archived thread.
