engine tranny swap #508229 10/01/04 01:53 PM
doc long Offline OP
do the dana300 and np231 have the same input and bolt pattern allowing a 4.0 liter with the factory tranny (auto or stick) to be swapped in? the info ive found is that they both have a round bolt pattern and 23 spline input. if not then does someone make an adapter?
since posting i found this:
http://www.bc4x4.com/faqs/yj.cfm?cat=6&faqid=131#faqtop
the whole reason for asking this is to avoid the cps issue and get a better tranny than the t5 at the same time.
thanks
Brian <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: engine tranny swap [Re: doc long] #508230 10/01/04 02:49 PM
Try going HERE - Advanced Adapters or HERE - NOVAK and see if you can find the info you need, they are both good sources of info,,,,
Re: engine tranny swap [Re: doc long] #508231 10/05/04 04:30 PM
Yes, they are compatible. The only difference is the clocking. A Dana 300 bolted to a tranny that once housed a NP231 will be rotated slightly differently than if it were bolted to a tranny for a 300. Does that make sense?
In other words, it may hang lower or be higher than it would normally be.
Re: engine tranny swap #508232 10/06/04 02:07 PM
doc long Offline OP
yup, makes perfect sense.
i know a guy that has a 4.0 with auto for $800.
not bad if im scrapping the t5 at the same time
Re: engine tranny swap #508233 10/16/04 03:38 AM
Macka Offline
higher would be good for clearance but that could add a whole new game for drive angles etc if your lifted.
always working
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.5980 MB (Peak: 0.6609 MB) Data Comp: Off Server Time: 2026-11-17 11:10:57 UTC
