Fuel filter #508404 10/01/04 10:31 PM
letmrun Offline OP
95 T100.... Having a stubborn time breaking the line free from the fuel filter and trying not to round off the 14mm nuts that secure both ends. I did manage to free up one end using a 'little' heat from a propane torch [flame at LOWEST possible setting] on the threaded inlet part of filter but the other end is not cooperating. Besides cleaning the area up with a wire brush and using a penetrating oil [BLASTER] does anyone have success using other methods to break these lines free?.......Normally I would just use more heat [expansion/contraction/repeat] but being a fuel line I've only heated it enough to where its still touchable.
Thanks.
Mine- 95 T100 4X4
Wife- 97 Rav 4
Re: Fuel filter [Re: letmrun] #508405 10/01/04 10:36 PM
4
4xGeek Offline
Heat? Flame? Torch? YIKES. Not the best place to be doing that! <img src="/forums/images/graemlins/shiner.gif" alt="" />
From what I've heard, PB or the stealership is your only recourse... <img src="/forums/images/graemlins/cheers.gif" alt="" />
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
Re: Fuel filter [Re: letmrun] #508406 10/01/04 10:36 PM
surlynkid Offline
we've all been there. <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Fuel filter [Re: surlynkid] #508407 10/01/04 10:38 PM
4
4xGeek Offline
Not all... Some have decided to leave well enough alone (for now, at least). <img src="/forums/images/graemlins/smile.gif" alt="" /> Then again, I'm only now @ 94k... But she's still gettin' gas now, so I ain't gonna mess with it just yet.
4xGeek (Chris)
Re: Fuel filter [Re: letmrun] #508408 10/01/04 11:14 PM
T-Rex Offline
The fuel filters on Toyota looks so easy as it's right along the side of the frame. Will, the last time I changed the fuel filter, it took me the whole afternoon after stripping the connectors. I ended up paying the local garage to finish the job, and about a $100 for new brake lines and labor.
This is one easy job that's best left to the professionals. Good luck.
02 Tacoma Double Cab TRD Prerunner .. just added 3" lift .. more to come
Re: Fuel filter [Re: letmrun] #508409 10/01/04 11:55 PM
surlynkid Offline
mine was the huge PITA you hear about. my brother's was a piece of cake. who knows.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Fuel filter [Re: surlynkid] #508410 10/02/04 06:36 AM
Are you using a wrench to stabilize the filter and another line wrench to loosen the line fitting? I just changed the fuel filter on my 1995 T100 and it only took about 45 minutes. The key is you need to use two wrenches and stabilize the filter, otherwise you'll just strip out the line fitting.
Re: Fuel filter #508411 10/02/04 01:39 PM
surlynkid Offline
yes, two wrenches.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Fuel filter [Re: surlynkid] #508412 10/02/04 01:45 PM
jroc Offline
propane torch on the fuel line............ <img src="/forums/images/graemlins/shocked.gif" alt="" />
And then there was this thing called Darwin Awards and............ <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Fuel filter #508413 10/02/04 01:48 PM
letmrun Offline OP
Yes, using two wrenches is a must. Being a retired motorcycle mechanic [25 years] you do learn a few things.
Thanks for the input though.
Mine- 95 T100 4X4
Wife- 97 Rav 4
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6345 MB (Peak: 0.7568 MB) Data Comp: Off Server Time: 2026-06-21 06:21:16 UTC
