1995 Grand Cherokee front axle shaft R&R question #510400 10/07/04 03:32 AM
Marc M Offline OP
One of my dad's 4 jeeps is having an issue. One of his front axle shafts on his '95 GC is bad. I told him I would see if you Jeep guys would know how to fix or replace it. I looked in the tech section but didn't see anything. Can the CV joint be replaced or does the whole shaft have to be replaced. Are their any special tools required to do the job ??
Marc
Proud Toyota owner <img src="/forums/images/graemlins/notooth.gif" alt="" />
'06 Tacoma Dbl-cab, 4X4, V6, 6-spd, SR5/TRD....
'90 4Runner 4X4 SR5 5-Spd
'86 Shortbed 4X4 5-Spd, SAS'd ASAP
'82 Supra 5-Spd
Take your automatic and "Stick" it........
My Web Album in Progress
Re: 1995 Grand Cherokee front axle shaft R&R question [Re: Marc M] #510401 10/07/04 06:19 AM
the CV joint's u-joints are probably bad. replaceing those can be a bit more involved, but if you take your time and use a vise with a small socket big socket aproach, it will work fine.
Re: 1995 Grand Cherokee front axle shaft R&R question [Re: Marc M] #510402 10/08/04 12:29 AM
I had the same issue on my '97 which lead me to this article http://www.4x4wire.com/jeep/tech/axle/weak_link/ call up South Bay Driveline they'll hook you up. I've been riding on mine for over 30k and no problems. It's a very easy conversion.
Re: 1995 Grand Cherokee front axle shaft R&R question #510403 10/08/04 12:59 AM
RE: 1995 Grand Cherokee front axle shaft R&R question [Re: Marc M]
#604932 - 10/06/04 10:19 PM
after re reading the post today.. i have came to the conclusion that speedreading at 10:20 after working hard all night is probably not the best way to give the right advice.
you can go to a junkyard and get and axle shaft from either a cherokee or a grandcherokee as long as it doesn't have an axle disconnect and it shoudl work. if your jeep has ABS the axle shaft you get to replace it will need to come with the metal counter ring for the abs or your ABS light will come on and you will only have normal hydrolic brakes.
Re: 1995 Grand Cherokee front axle shaft R&R question [Re: Marc M] #510404 10/08/04 11:49 PM
Is there an "online" site that references Jeep service manuals?? ie: specific instructions on R&R front axle on 95 Jeep Grand Cherokee Limiteds
Re: 1995 Grand Cherokee front axle shaft R&R question #510405 10/09/04 12:11 AM
not rteally, but its very striaght forward. a chilton will give you enough info to r&r one.
Re: 1995 Grand Cherokee front axle shaft R&R question #510406 10/09/04 04:48 AM
Marc M Offline OP
Hey dad, go to the link in the reply from ZJ 318. It has all the info you need..........
I told you to buy a Toyota.......... <img src="/forums/images/graemlins/nana.gif" alt="" />
J/K
Marc
'82 Supra 5-Spd
Re: 1995 Grand Cherokee front axle shaft R&R question [Re: Marc M] #510407 10/09/04 12:32 PM
Well get over here and help!!! <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6087 MB (Peak: 0.6899 MB) Data Comp: Off Server Time: 2026-06-07 03:39:29 UTC
