Re: 4.875 Gears
[Re: powerRam50]
#510753
10/08/04 07:25 AM
Dan,
You're talking about 4-cylinder diffs, right? I'm about 99.999% convinced that 4.88s for the 6-cylinders were never imported into the U.S. Quite a few people have said they've had (or at least seen) 4.88s for the 4-cylinders. I may be hitting some junkyards soon, I'll see if I can find any.
Are you sure you don't have some lying around your yard somewhere <img src="/forums/images/graemlins/lol.gif" alt="" /> ?
Re: 4.875 Gears
[Re: Jim_B]
#510754
10/08/04 03:02 PM
I actually thought all Gen I 5spds had them. I do know my 89 4dr, 904dr, and 84 all had them. The 93sr Auto was the first Montero I owned with 4:62 instead.
Re: 4.875 Gears
[Re: Jim_B]
#510755
10/08/04 04:23 PM
man the set i found only cost me 175 total for both front and rear and the junk yard pulled them for me.i am still looking for a set for my truck but i will settle for 4.6 if it has the lsd,maybe i might just weld it up but i am not sure yet.
Re: 4.875 Gears
[Re: Lloyd Swartz]
#510756
10/08/04 05:59 PM
I actually thought all Gen I 5spds had them. I do know my 89 4dr, 904dr, and 84 all had them. The 93sr Auto was the first Montero I owned with 4:62 instead. Your '93 should have also had 4.88's, if it was the SR. The SR's didn't get the 4.63's until it got the 3.5L V6 and large rear diff in '94. The LS had 4.62's because they came with smaller tires.
Lee '94 LS, 3.0 V6, Auto, completely stock
Re: 4.875 Gears
[Re: Jim_B]
#510757
10/08/04 07:18 PM
I'm about 99.999% convinced that 4.88s for the 6-cylinders were never imported into the U.S. Correction: I should have written 6-cylinder Gen Is .
Re: 4.875 Gears
[Re: Jim_B]
#510758
10/08/04 07:30 PM
4.88'S were never offered by Mitsubishi in the Gen-1 V-6. Kary
1987 Mitsubishi Pajero "Modified" The other original Mitsu brother Northwest Trailmaster
Re: 4.875 Gears
[Re: Big Blue]
#510759
10/08/04 07:46 PM
4.88'S were never offered by Mitsubishi in the Gen-1 V-6. Kary Lloyd says they were, so you must be wrong... <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/drunk.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> (I own two Gen I 6-cylinder 5-speeds; they're both 4.625s. Additionally, I've got two diffs out of other Gen I 6-cylinders (I bought them at junkyards to get the LSDs). They're both 4.625, as well. Every Gen I 6-cylinder I've ever seen in a junkyard had 4.625s).
Re: 4.875 Gears
[Re: Jim_B]
#510760
10/08/04 09:27 PM
4.88s were available starting on early GenIIs.
Re: 4.875 Gears
[Re: Big Blue]
#510761
10/08/04 11:22 PM
4.88'S were never offered by Mitsubishi in the Gen-1 V-6. Kary Yes they were............ Just because the US didn't get them doesn't mean they don't exist just like the 5.29's <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
I just luv my "clacker Jabber".................
Re: 4.875 Gears
[Re: DaphneD]
#510762
10/08/04 11:54 PM
4.88s were available starting on early GenIIs. How would you know what you had in your GenII? I've no idea what mine has...is there some sort of marking on the carriers?
