Page 2 of 4 1 2 3 4
Re: 4.875 Gears [Re: powerRam50] #510753 10/08/04 07:25 AM
Jim_B Offline
Dan,
You're talking about 4-cylinder diffs, right? I'm about 99.999% convinced that 4.88s for the 6-cylinders were never imported into the U.S. Quite a few people have said they've had (or at least seen) 4.88s for the 4-cylinders. I may be hitting some junkyards soon, I'll see if I can find any.
Are you sure you don't have some lying around your yard somewhere <img src="/forums/images/graemlins/lol.gif" alt="" /> ?
Re: 4.875 Gears [Re: Jim_B] #510754 10/08/04 03:02 PM
Lloyd Swartz Offline
I actually thought all Gen I 5spds had them. I do know my 89 4dr, 904dr, and 84 all had them. The 93sr Auto was the first Montero I owned with 4:62 instead.
Re: 4.875 Gears [Re: Jim_B] #510755 10/08/04 04:23 PM
powerRam50 Offline
man the set i found only cost me 175 total for both front and rear and the junk yard pulled them for me.i am still looking for a set for my truck but i will settle for 4.6 if it has the lsd,maybe i might just weld it up but i am not sure yet.
Re: 4.875 Gears [Re: Lloyd Swartz] #510756 10/08/04 05:59 PM
L
Lee N Offline
Your '93 should have also had 4.88's, if it was the SR. The SR's didn't get the 4.63's until it got the 3.5L V6 and large rear diff in '94. The LS had 4.62's because they came with smaller tires.
Lee
'94 LS, 3.0 V6, Auto, completely stock
Re: 4.875 Gears [Re: Jim_B] #510757 10/08/04 07:18 PM
Jim_B Offline
Correction: I should have written 6-cylinder Gen Is .
Re: 4.875 Gears [Re: Jim_B] #510758 10/08/04 07:30 PM
Big Blue Offline
4.88'S were never offered by Mitsubishi in the Gen-1 V-6.
Kary
1987 Mitsubishi Pajero "Modified"
The other original Mitsu brother
Northwest Trailmaster
Re: 4.875 Gears [Re: Big Blue] #510759 10/08/04 07:46 PM
Jim_B Offline
Kary
Lloyd says they were, so you must be wrong... <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/drunk.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
(I own two Gen I 6-cylinder 5-speeds; they're both 4.625s. Additionally, I've got two diffs out of other Gen I 6-cylinders (I bought them at junkyards to get the LSDs). They're both 4.625, as well. Every Gen I 6-cylinder I've ever seen in a junkyard had 4.625s).
Re: 4.875 Gears [Re: Jim_B] #510760 10/08/04 09:27 PM
DaphneD Offline
4.88s were available starting on early GenIIs.
Re: 4.875 Gears [Re: Big Blue] #510761 10/08/04 11:22 PM
Mister Bishi Offline
Kary
Yes they were............
Just because the US didn't get them doesn't mean they don't exist just like the 5.29's <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
I just luv my "clacker Jabber".................
Re: 4.875 Gears [Re: DaphneD] #510762 10/08/04 11:54 PM
stony-man Offline
How would you know what you had in your GenII? I've no idea what mine has...is there some sort of marking on the carriers?
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6389 MB (Peak: 0.7636 MB) Data Comp: Off Server Time: 2026-11-06 23:08:53 UTC
