Page 2 of 3 1 2 3
Re: Slight rant. Comments welcome #510788 10/08/04 10:48 PM
derangedcj Offline OP
Well this engine has been rebuilt once. About 5-6 years ago. So i dont really know. And the way i know its not oil, Its pink. And its clean. I crawled under it and watched it leak.
83 CJ-7 3 in suspension. All problems currently fixed. Just Everyone Elses Parts. JEEP
Re: Slight rant. Comments welcome [Re: derangedcj] #510789 10/09/04 12:10 AM
the repair is fairly simple. you pll the tranny you pull tourq converter you pull oil pump housing pound out old seal put in new seal replace oil pump housing with new seal, reinstall tourq converter reinstall tranny.
Re: Slight rant. Comments welcome #510790 10/09/04 12:37 AM
Well heres a picture of the Battery.
And here are some pictures of the leak.
Pink and cloudy. With water. He forgot to hook up the vent line.
Leak is on the right side of image. From left is the rear of tranny right is right of tranny. <img src="/forums/images/graemlins/kewl.gif" alt="" /> you can see a small line of pink fluid. I wiped it off not 10 seconds before picture.
Re: Slight rant. Comments welcome [Re: derangedcj] #510791 10/09/04 01:59 AM
if it is over full from having water mixed in with it, it will casue it to leak. since it has water in it i would drain and refill it to the propor level and see if that does anything.
that battery shure does look like a battery. you need to check it with a voltmeter. if it continiuosly cranks the battery is probably fine, it should alst 5 years.
Re: Slight rant. Comments welcome #510792 10/13/04 02:44 PM
Well its started again. Or rather it failed to start. When i turn the Keys it goes CLICK...its not the battery it checked out good. Its not the alternator it checked out good. Its not the sloiniod it checked out good. Could it be the wires running from it to the disrtibuter coil have gone bad? or is it the starter? i took the plastic piece off the coil to see if that made it not click and it still clicked like it had been. So im leaning towards bad coil wires. Aghh got class need help to get to class... <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: Slight rant. Comments welcome [Re: derangedcj] #510793 10/13/04 03:51 PM
if it goes click and fails to turn over, its gotta be the starter if you verified the batery is good. the coil would only cuase it to not fire when cranking.
Re: Slight rant. Comments welcome [Re: derangedcj] #510794 10/13/04 04:16 PM
What happens when you try jumping it from another vehicle? How did you verify it's not the battery?
Re: Slight rant. Comments welcome #510795 10/13/04 05:11 PM
Well as soon as someone can pick me up a new starter i will see how it works. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Slight rant. Comments welcome [Re: derangedcj] #510796 10/13/04 08:15 PM
Did you remove and clean all the power wires and grounds... mine was at the starter it was all rusty, did you try booster cables directly to the starter?
Re: Slight rant. Comments welcome #510797 10/13/04 09:50 PM
I tried and checked everything. When I had someone turn the keys while i was hitten the starter with a hammer it turned over...So I replaced the starter and it all works now. Thanks guys. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6307 MB (Peak: 0.7365 MB) Data Comp: Off Server Time: 2026-06-10 01:30:06 UTC
