Re: Slight rant. Comments welcome
[Re: derangedcj]
#510798
10/19/04 11:04 PM
Getting back to the Leak. I have already paid about 380 to get it all fixed. The first time it was seals on the rear tranny. Next time was front seals and they epoxied in a bearing in the front. I talked to the guy today and i had spun the epoxied bearing with normal driving. He claimed this was a first. But now my case is royally screwed. Hes like we can replace the case and fix it for about $550. So with the 380 already and another $550 That over $900. A new tranny is about $1,200 so should i go with a new Tranny or get this guy to fix it. I am way lacking in trust with this guy now... A little advise would be nice. <img src="/forums/images/graemlins/kewl.gif" alt="" />
83 CJ-7 3 in suspension. All problems currently fixed. Just Everyone Elses Parts. JEEP
[Re: derangedcj]
#510799
10/19/04 11:12 PM
epoxy the main suport bushing in the case?? WORNG! if the case is damaged to the point where a new bushig will no longer press fit in its time for a new tranny....
#510800
10/19/04 11:35 PM
Well if i pay $550 they will recase it. I can get my $380 back and walk or put it towards a new case.
[Re: derangedcj]
#510801
10/20/04 01:15 AM
well... its going to go somthing like this...
We got your new case in and we started installing parts and found your forward cluthc pack is out of tolerance, and you low/reverse drum is messed up.. We can put it back together for you but it will fail in a month... ETC
for if you can get your 380 back.. do it and put it twards a new/rebuilt tranny.
#510802
10/20/04 02:14 AM
Well if i replace it should i put in a different type or whould that require a new bellhousing if i got say a t-150? Also know any good places to get em. Im looken but its alot to look through <img src="/forums/images/graemlins/kewl.gif" alt="" /> Would a t150 work with a mdl 300? Or would i need like a 20?
[Re: derangedcj]
#510803
10/20/04 07:00 AM
unless you have serious issues with what you have now (before it broke) i would leave it stock. it makes it easier to work on and get parts for. and it will still look very clean wiht minimal effort.
of course if you really want the t150... adaptor plates are available for anything. i wouldn't know off the top of my head if those bolt together easily.
#510804
10/20/04 03:35 PM
don't even consider a 20. low range blows. keep the 300 at all cost.
[Re: derangedcj]
#510805
10/20/04 07:17 PM
I don't think a t-150 and a 300 came like that from factory. I put a t-18/dana20 in place of my 150/dana20 because the first gear in the t-150 "blows" <img src="/forums/images/graemlins/lol.gif" alt="" /> The dana 20 has a poor low range compared to the 300.
PHP: 7.4.33 Page Time: 2.644s Queries: 16 (0.004s) Memory: 0.6210 MB (Peak: 0.7185 MB) Data Comp: Off Server Time: 2026-06-13 14:07:23 UTCValid HTML 5 and Valid CSS
