Page 3 of 4 1 2 3 4
Re: My 3.0 manifold progress (pics) [Re: Ganoid] #512413 12/31/04 05:32 PM
CORunner93 Offline
Impressive!!
I would have thought for sure you'd have had a problem sealing each runner, when it was welded. And, that would have lead to some bypass between the runners. Which would have been noticable in some way....rough idle, stumbling during a certain RPM range....something.
You should get DOA heads AND a ported TB. Those would be a nice compliment to the ported manifold....or vice-a-versa.
I think regardless you should get a dyno test done......See what the results really are.
'93 4Runner - 3.4L 5VZ-FE, 2" body lift, on-board-air system, custom gauge cluster, rear e-locker, electric fan, custom built front and rear bumpers, sliders, 4,88 gears...all on 33x12.5's.
Re: My 3.0 manifold progress (pics) [Re: CORunner93] #512414 12/31/04 10:16 PM
Ganoid Offline OP
There I add the sig to that last post. I have DOA heads and cams... for what thier worth?
90 Xcab V6
3.0 Rebuilt/Balanced
P/P w/OS valves
Downey Hdrs,Jacobs Ign
5.29's,Tru Trac+Lockright
4"TG SAS+Rear Kit on 35's
(DOA Racing = $1200 lesson <img src="/forums/images/graemlins/angry.gif" alt="" />)
www.performancecylinderheads.com
Re: My 3.0 manifold progress (pics) [Re: Ganoid] #512415 12/31/04 11:09 PM
bkg Offline
Out of curiousity... any increase in fuel efficiency? You planning to get it dyno'd?
Brian K. Gallus
Re: My 3.0 manifold progress (pics) [Re: Ganoid] #512416 01/01/05 01:45 AM
CORunner93 Offline
Ahhhh.....Touche'
Nice work.....now I'm really curious as to what your getting for horsepower.
Re: My 3.0 manifold progress (pics) [Re: CORunner93] #512417 01/01/05 06:10 PM
For what it's worth, even if the runners did not seal back up completely with the rewelding, air going between runners is no big deal. Look at the siamesed runners that SLP made for the Chevy 350 TPI engines. I'm wondering why you didn't just have the manifold Extrude Honed to increase and smooth out the runners. Other than the cost.
Re: My 3.0 manifold progress (pics) #512418 01/02/05 12:56 AM
Ganoid Offline OP
Here is a good reason against extrude hone I think.
http://www.extrudehone.com/price_list2.pdf
Im into my manifold for about $100 not counting my time playing with it.
90 Xcab V6
P/P w/OS valves
Re: My 3.0 manifold progress (pics) [Re: Ganoid] #512419 01/12/06 02:41 AM
Rauch_Off_Road Offline
So Ganoid, when you did this did you install it with other mods or on its own? If on its own how did you find the performance compaired to other mods you have done?
I'm trying to be a bit more agressive with mine but I wanna gauge the expected gains.
(aka suprathepeg, aka Sean)
Re: My 3.0 manifold progress (pics) [Re: Rauch_Off_Road] #512420 01/13/06 01:22 AM
I also noticed that you haven't got your EGR on there. Have you been getting the CEL at all?
Re: My 3.0 manifold progress (pics) [Re: Rauch_Off_Road] #512421 01/18/06 04:48 AM
Ker-bumpity.
Re: My 3.0 manifold progress (pics) [Re: Rauch_Off_Road] #512422 01/18/06 08:01 PM
Ganoid Offline OP
The EGR on mine created a huge flat spot around 2000-2700 (I removed it months before the manifold project). I plan on reinstalling it with some minor modifications but just have not made it around to doing so. When I put the manifold on it was a single upgrade deal. A few days later I installed a Jacobs Ignition system. Like the article said the manifold showed gains in all the unexpected areas (1800-3200 rpm). It could be that the manifold made gains up top as well and those where only apparent with the new ignition. I must say I was pretty darn happy with the truck but after my recent purchase and transition to "The Dark Side" I gotta say the 3.0 sucks. If Toyota would just put a motor like I have in my recently acquired 02 Maxima then I would be one happy camper. For what its worth I have never actually driven a stock 3.0 so I'm not a real good judge on performance increase. I just know on my already modified motor the manifold was totally worth it.
90 Xcab V6
P/P w/OS valves
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6402 MB (Peak: 0.7458 MB) Data Comp: Off Server Time: 2026-06-12 16:03:05 UTC
