Stabilizer bar drop bracket #512789 10/13/04 03:33 AM
Deron Offline OP
Does anyone know if a drop bracket is available for the rear stabilizer bar on the 3rd gen 4Runner to re-align the axle after installing a lift? I've had my truck lifted for over 2 years now and although I've had no problems I seem to be noticing lately that the axle is certainly shifted to the passenger side. I'm thinking of adding more lift but that would shift the axle over even further.
2000 4Runner, OME 882 front coils w/ firm shocks, 891 rear coils w/ firm shocks, Sonoran Steel adjustable rear panhard bar, ARB Prado bullbar, Warn 9,000lb. winch, Amsteel synthetic winch line, Hella Lights, 265/75R16 BFG All Terrains
Re: Stabilizer bar drop bracket [Re: Deron] #512790 10/13/04 03:06 PM
Wild_Bill Offline
Toyota Moderator
Something like this?
Do a search on panhard drop bracket, you should find something. You will need to have it welded though.
Bill
97 SR5 4WD
Yukon 4.88s, ARB locker front/rear, OME Lift w/ Cornfeds, 2 Body lift, Panhard drop, Custom gauges, Nuke discos, TJM T17,
My Runner
Re: Stabilizer bar drop bracket [Re: Wild_Bill] #512791 10/14/04 02:40 AM
Deron Offline OP
Yep, something like that. I meant panhard rod drop bracket. I know that drop brackets are available for 2nd gen 4Runners and they're bolt-on, no welding required. Any special reason why they need to be welded on the 3rd gen? Just curious.
Re: Stabilizer bar drop bracket [Re: Deron] #512792 10/14/04 06:26 AM
larsdennert Offline
PHP: 7.4.33 Page Time: 2.475s Queries: 15 (0.003s) Memory: 0.6021 MB (Peak: 0.6579 MB) Data Comp: Off Server Time: 2026-06-07 08:11:34 UTC
