serched to no avail....... a ranger rear spring swap on a gen1?
#513776
10/15/04 04:55 AM
has any one actualy done one???? i have read a few short threads that kick the idea around... but i cant find any real info... i was lookin at this because (depending on the work) it might be a much cheaper and better all around than the re-arching or addaleafs(both are going to make the spring stiffer and i dont want them much stiffer) i live in colorado and need some flex for the rocks but the ground clearance for snow ect.i was thinkin bout the soa but lots of people on here are adversed to that.........i dont know but i like the ranger leaf idea cuz there is a yard here that i could get some bronc 2 springs for cheap... ideas.??/ i geuss it will need to match cranked tbars (havent yet will do that when springs are underway)thanx in advance for the help.. <img src="/forums/images/graemlins/patriot.gif" alt="" />bobshaw..what did you end up doin i saw you had problems with your rear leafs on the 4.3 rig what fixed it??
Re: serched to no avail....... a ranger rear spring swap on a gen1?
#513777
10/15/04 09:17 AM
i DON'T KNOW ABOUT RANGER SPRINGS BUT THE S-10 SPRING UNDER MY 85 WORK VERY VERY WELL. YOU WILL NEED TO DO CUSTOM SHACKLES AND HANGERS BUT AS LONG YOU MEASURE ALOT AND DO ONLY ONE SIDE AT A TIME ITS GRAVY. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />ALSO ALOT OF GUYS AROUND HERE WITH TOYOTAS DO ASTO VAN REAR SPRINGS AND DODGE CARAVAN REARS.EVERBODY DOES IT FOR THE REASONS YOU TALK ABOUT..MORE TRAVEL MORE CLEARANCE THEY DON'T SAG HANDLE BETTER. YOU KNOW...GOOD LUCK AND JUST DO IT <img src="/forums/images/graemlins/patriot.gif" alt="" />
85 monty swb,full 4.3swap,5spman&hd231tcase,34"swampers,dualbouncy, softop done,new tbars,S10 rear spring w/dual shackles.
[Re: 85monteroS]
#513778
10/15/04 02:59 PM
I've looked at it extensively, and done all the math, but I was also going to do an SOA with it. I'm not so sure that the work is worth it, as mine flex's very well. As much as I would like to do it, Unless i can get a 10" travel shock into the mix, then for me it's just a change. I don't know how much you have wheeled yours, but I can put a front, or rear on a 28" tree trunk and have the other three on the ground. If you are looking at "cheap" fix's then there are none that do it all. You also have a slip yoke, and I don't. You may/will need to deal with the "e-brake" cables if you really want it ot flex, as you will find that they get in the way. As I said, I was looking at an SOA with 10" travel shocks, mounted higher then the stock location. Good luck
PS. 85 monteroS; fix your caps key <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> Kary
1987 Mitsubishi Pajero "Modified" The other original Mitsu brother Northwest Trailmaster
[Re: Big Blue]
#513779
10/16/04 02:05 AM
Kary,... what kindof set up are you running now??? addaleafs??just wondering cuz if i could have one tire 28in off the ground and the rest of them planted that would be great... even tho i dont realy know what the stock will do...i have only had it running a week and no tag etc. so i cant realy go very far quite yet...
#513780
10/18/04 02:40 PM
has any one tryed XJ rear springs????huumm...
#513781
10/18/04 09:47 PM
Are you looking for lift, or are yours worn out? If the latter, I had two donors for my gig and one had decent springs and the others were worn out from towing a boat. I have the good ones on now and all seems fine. So if you just need to replace yours, maybe the bone-yard is your cheapest route.
[Re: MontyMcV]
#513782
10/19/04 01:20 AM
not actualy wore out but i would like a little bit of lift like 2 inch etc... i got the xj springs from the bone yard for 50 and i can rerturn them within 30 days so i might try several diffrent kinds before i find a winner..ya know the ole geuss and check <img src="/forums/images/graemlins/patriot.gif" alt="" />
#513783
10/19/04 03:24 AM
Like I said, the add-a-leafs did give noticeable lift, though I don't know how much. But it would also literally bounce over bigger bumps. Cornering sometimes wasn't fun.
Good luck on the mission and keep us posted.
[Re: MontyMcV]
#513784
10/19/04 02:02 PM
will do!! mabe i will discover a new trend..lol <img src="/forums/images/graemlins/patriot.gif" alt="" />
