Yeah, the sensor is a ways back there and I have read that it'll even cool off enough to fall out of Closed Loop if you sit and idle for prolonged periods. One reason why the SFI 3.4 locates them in the exh. man's. You'll see the V8's the same way. Better metering and the sensor stays nice and toasty warm all the time.
Also have read where a few tuners have installed the 3-wire heated O2 sensor in the original position with success.
Although there may be issues with leaving the heater on all the time vs. the usual way mfr's do it, which is to have some sort of timing device on it.
Proably a good question to pose to the Super Tuners at this site:
http://www.60degreev6.com/index.php...NUKESID=7a6076e486e332eda6e50a2fb5eaf509BTW I wouldn't think it'd work too well to sense off of one side only. I expect GM would have done that if it was beneficial to operation.
Sensing the combined exhaust of both sides (notwitstanding the heating issue) is probably a more accurate way to do it, in the absence of dual sensors.
I just wonder, is the fact that the exhaust gasses are cooled somewhat by the time they reach the O2 sensor a contributing factor in that most 2.8's you see have a black tailpipe from running a bit too rich???? Hmmmmmmm......Just a thought! <img src="/forums/images/graemlins/coolg.gif" alt="" />
I've still got the stock wheezy exhaust so can't attest to ultimate mpg but most relate that it's better than the 2.8, as long as you keep your foot out of it!! <img src="/forums/images/graemlins/smile.gif" alt="" />
