Re: Replacement rear springs? #515005 10/18/04 02:15 PM
4
4xGeek Offline OP
Lot's o' questions:
Who here have replaced their rear springs?
What companies?
What's the stock spring length & rate?
Did anyone go up/down in length or rate?
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
Re: Replacement rear springs? [Re: 4xGeek] #515006 10/18/04 02:58 PM
H2O_MAN Offline
I went with Alcan <img src="/forums/images/graemlins/kewl.gif" alt="" />
I had them give me 1" additional lift and 500 pounds of extra capacity.
I have over 100K problem free miles on them.
NOTE: I do have Air-Lift bags, HD Bilsteins and a Hellwig.
Re: Replacement rear springs? [Re: H2O_MAN] #515007 10/18/04 08:55 PM
4
4xGeek Offline OP
How many leaves\how thick is it?
4xGeek (Chris)
Re: Replacement rear springs? [Re: 4xGeek] #515008 10/18/04 11:16 PM
mmiller Offline
As I recall, they(Alcan) take the amount of lift, payload, and use into consideration, and design them accordingly. I wanted to replace my 4" blocks, so I got 2.5" springs (1.5" from shackles). I have been very happy with mine-around $400. See comparison below.
1997 T100 4x4 SR5 5spd
Re: Replacement rear springs? [Re: mmiller] #515009 10/19/04 03:59 AM
4
4xGeek Offline OP
Cool... Thanks guys. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Did you get them direct or thru All-Pro? IIRC, I think it may be a little cheaper thru them.
MMiller, is your lift on the new springs a total of 4", or is it just 2.5"?
4xGeek (Chris)
Re: Replacement rear springs? [Re: 4xGeek] #515010 10/19/04 06:18 PM
mmiller Offline
The total is 4", but the spring is only 2.5". The longer shackle (AOR) adds about 1.5" of lift. If you didn't replace the shackle, you would need a 4" spring, but may lose some flex movement with the stock shackle. I knew I would replace the shackle, so I only ordered my spring with 2.5" of lift over stock. I also figured this would give me some adjustment room if the spring lift was too high. The fit turned out to be perfect.
Re: Replacement rear springs? [Re: mmiller] #515011 10/20/04 12:09 AM
Kookadala Offline
I see you did not use a greasable shackle, was that available for the T?
96 T100 4x4 - 35's, 4" SL, 2" BL, 4.88s, ARBs, custom bumper & E9000 winch, etc.
99 F-350 4x4 superduty supercab turbodiesel longbed
Re: Replacement rear springs? [Re: Kookadala] #515012 10/20/04 01:24 AM
mmiller Offline
AOR does have a greasable shackle for $20 more. I'm not sure why I didn't go that route at the time. If Tacoma and T100 are the same, I guess there must be lots of shackle choices out there.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6212 MB (Peak: 0.7042 MB) Data Comp: Off Server Time: 2026-06-18 05:45:44 UTC
