Page 4 of 12 1 2 3 4 5 6 … 11 12
Re: Finally, new motor going in :) [Re: houlster] #515263 11/09/04 10:40 AM
Jeff the marmot Offline
Looks awesome, Dan!
Just to mention another name, www.spidertrax.com has a fair amount of CNC equipment in their 4x4 shop. Both Tom and Eddie are quite experienced with CNC stuff. I don't know if they'd be affordable, but that's just another possibility for you.
Jeff
2000 4Runner SR5, supercharger, rear e-locker, ARB front locker, 285/75R16 MT/R's, custom bumpers & skids
2007 Tacoma double cab 4x4 - stock
Re: Finally, new motor going in :) [Re: Jeff the marmot] #515264 11/09/04 05:28 PM
thepcguy Offline
Now that's more like it!. ::eerily peers out at the trooper, begins the evil laugh, excellent::. I know how that motors performs without the supercharger (Parents have a 1992 bonneville, and I had a '87) and boy would it be sweet in my trooper. However, my 2.6 is still running strong. So for now, I'll simply stare at yours. Man, 4wd although so beautiful, really makes any engine replacements other than the stock, a pain in the <img src="/forums/images/graemlins/butwiggle.gif" alt="" />. Either way, best of luck buddy <img src="/forums/images/graemlins/kewl.gif" alt="" />. Keep us posted.
- Jim
1989 Isuzu Trooper II
- 2.6L 4ze1 Motor
- BFGoodrich 235/75/15 AT
Re: Finally, new motor going in :) [Re: houlster] #515265 12/12/04 12:37 AM
houlster Offline OP
Isuzu Moderator
Done a little wiring <img src="/forums/images/graemlins/scared.gif" alt="" />
I pulled the whole harness out and removed all the EFI wires and the ECM from it one by one (about 2/3 of the wires in the harness). It was bugging me leaving all that crap in there.
I think with the dash out, I'm gonna yank the nasty, filthy, dusty, dirty carpet out too and spray in a bedliner before putting the dash back in.
Re: Finally, new motor going in :) [Re: houlster] #515266 12/12/04 12:49 AM
houlster Offline OP
Isuzu Moderator
Got the motor mounts made a couple weeks ago. Here's the mock-ups. I used a cereal box to make the templates, then transfered to steel to get here.
Then pulled the motor back out to brace and finsh them:[Linked Image]
The frame mounts are folded over into a 'U' shape, welded 3 passes on all sides and an additional brace is underneath going around the bottom of the frame rail.
Re: Finally, new motor going in :) [Re: houlster] #515267 12/12/04 12:53 AM
Rodeo Clown Offline
Looks good. Can't wait to see it finished. <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
1997 Isuzu Rodeo - Auto - 31" ATs
1995 Honda Passport - 1 tons - 39" Boggers
Re: Finally, new motor going in :) [Re: houlster] #515268 12/12/04 12:54 AM
houlster Offline OP
Isuzu Moderator
So far, I have the passenger side header tacked up. I'm still waiting for some more pieces to come in. It'll be cut at the bottom and a ball-joint attached to make removal easy. This side really hugs the block so that the cross-over pipe that will attach to it will clear the front driveshaft.
Still working on the driver's side. It's a bit more complicated because of the A/C compressor and starter both being right there.
--Dan
Re: Finally, new motor going in :) [Re: houlster] #515269 12/12/04 12:56 AM
strawmyers Offline
Isuzu Moderator
I'm pretty sure if I walked out to my truck and saw that kind of wiring project ahead of me........... I would be found days later, in the corner curled up in a fetal position <img src="/forums/images/graemlins/baby.gif" alt="" />
Cool to see the project coming along and good luck........... but dang that's a lot of wires <img src="/forums/images/graemlins/scared.gif" alt="" />
Sean Strawmyer
Re: Finally, new motor going in :) [Re: strawmyers] #515270 12/12/04 01:02 AM
houlster Offline OP
Isuzu Moderator
hehe. Wiring is one of those things that looks awful, but really isn't all that bad. Everything is color coded and as long as you have the factory shop manual calling out wire colors and pin numbers, tracing them pin to pin is really pretty easy. It's time consuming and it can be confusing some times, but really it's not nearly as bad as it looks.
Without the *factory* manual and wiring diagrams??? forget it. You would go nuts.
--Dan
Re: Finally, new motor going in :) [Re: houlster] #515271 12/12/04 01:08 AM
L
Landmonster Offline
I think my head just exploded. <img src="/forums/images/graemlins/zombie.gif" alt="" />
Don't you just love working on newer cars?
Good luck with the project, and thanks for the update. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Finally, new motor going in :) [Re: Landmonster] #515272 12/12/04 02:33 AM
CPOM Offline
Are you using the Isuzu harness modified to the 3800 sensors, or the 3800 harness with unused wires removed?
CHRIS
98 Amigo, 92 Pup
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.010s) Memory: 0.6549 MB (Peak: 0.7792 MB) Data Comp: Off Server Time: 2026-11-16 17:52:47 UTC
