Page 5 of 12 1 2 3 4 5 6 7 11 12
Re: Finally, new motor going in :) [Re: CPOM] #515273 12/12/04 03:28 AM
houlster Offline OP
Isuzu Moderator
Are you using the Isuzu harness modified to the 3800 sensors, or the 3800 harness with unused wires removed?
Neither, I'm using a MegaSquirt. I didn't cut the EFI wires out of the harness, but removed the pins from their connectors so I could re-use them if I wanted to. I may make a new harness for the MS re-using the stock wires and connectors, but I've already got a harness for it in the truck. Just depends how ambitious I get.
--Dan
Re: Finally, new motor going in :) [Re: houlster] #515274 12/12/04 11:43 PM
mlclark Offline
Isuzu Moderator
This has got to be one of the funniest things I have read, especially coming from Dan. <img src="/forums/images/graemlins/smile.gif" alt="" />
Michael
Re: Finally, new motor going in :) [Re: houlster] #515275 12/13/04 12:14 AM
only one thought comes to mind...purty..
droool... <img src="/forums/images/graemlins/barf.gif" alt="" />
Re: Finally, new motor going in :) [Re: houlster] #515276 12/30/04 04:29 PM
houlster Offline OP
Isuzu Moderator
Headers are done. Still completing the cross-over tube:
And, I can still get the motor mount bolt out in that last pic smile
--Dan
Re: Finally, new motor going in :) [Re: houlster] #515277 12/30/04 05:12 PM
Sc0rp10n Offline
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Nick <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
2000 XJ Classic - Classically a POS
1994 Isuzu Amigo XS -Sold
1972/3 CJ5 Glass body, 5" lift 34's. 5 years of work coming to an end.
Re: Finally, new motor going in :) [Re: houlster] #515278 12/30/04 05:58 PM
houlster Offline OP
Isuzu Moderator
Had a brain fart when I did the passenger side header. I left room to get the spark plug out, but the boots were out-of-sight out-of-mind. I had to bash the #2 tube for the boot to fit:
Decided that was waaay too ugly and restricting, so, cut:
And paste in a new one with more room for the plug boot:
--Dan
Re: Finally, new motor going in :) [Re: houlster] #515279 12/30/04 06:04 PM
L
Locomigo Offline
Dan, I mean this in the best possible way, but your meticulousnous, attention to detail, and fab skills are SICKENING <img src="/forums/images/graemlins/barf.gif" alt="" />.
That is freakin amazing, you dont even see the seam in that pipe, that is truly incredible, and a LOT of work for a small adjustment, althouogh very worthwhile...
I am looking forward to seeing your rig in Moab this year, it just keeps gettin better. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Finally, new motor going in :) [Re: houlster] #515280 01/10/05 08:21 PM
Dan, really interested in how the megasquirt worked with your turbo set up. I had the same issues as you while I had the turbo on my trooper, but never got a chance to put my megasquirt on... I used radiator hoses to route my air, and had a big 90 degree going into the compressor inlet... well there was a big spring in the hose to keep it from colapsing... and I was working it around to get underneath and that bastard worked it's way into the turbo.
But I've decided to revisit it, so I need to either source another turbo, or get mine rebuilt.... But I definitely want to squirt it. Always good to get advice from some one who's been there. Was also wondering if you squirt'n'sparked it, looks like it will definitely work.
Rody
Re: Finally, new motor going in :) #515281 01/11/05 03:54 PM
L
Landmonster Offline
Just out of curiosity, where did you get those two 'ball and cup' exhaust couplers?
I can't remember the correct name for them, but hopefully you understand what I'm trying to say.
Were they sourced locally, or online?
Re: Finally, new motor going in :) #515282 01/11/05 05:14 PM
houlster Offline OP
Isuzu Moderator
Dan, really interested in how the megasquirt worked with your turbo set up. Was also wondering if you squirt'n'sparked it, looks like it will definitely work.
The MS worked exceptionally well. Biggest improvement was in throttle response. I've got the map if you want to use it. My injectors are larger than the earlier 2.6, but the map itself should be a good starting point for tuning.
I never did the S'n'S. I had an MSD BTM ignition that worked ok, and I knew I was going to be doing an engine swap so I didn't work on it.
--Dan
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6511 MB (Peak: 0.7628 MB) Data Comp: Off Server Time: 2026-06-20 18:00:15 UTC
