Page 8 of 12 1 2 … 6 7 8 9 10 11 12
Re: Finally, new motor going in :) [Re: Jim_Paget] #515303 03/03/05 07:44 PM
houlster Offline OP
Isuzu Moderator
I can drop in next week to see if I can get some more info, if you like.
Hey Jim, yeah, I'd like to see the info. In case I do need an upgrade, it'd be great if it can be done using the stock size radiator using the existing mounts.
Re: Finally, new motor going in :) [Re: houlster] #515304 03/04/05 11:44 PM
Jim_Paget Offline
I will drop in to talk to the guy early next week.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Finally, new motor going in :) [Re: Jim_Paget] #515305 03/05/05 04:49 AM
W
Wayne Offline
He was telling me about some newer technology where they are dimpling the tubes which leads to better cooling by breaking up the flow resulting much better cooling, particularly in high performance applications.
My snake oil alarm is going off. I'm not saying it doesn't work, but adding turbulence would, if anything, lead to greater pressure. Not much in this low-pressure application, of course, but still. It might cool the water better over stock by keeping it in the radiator longer....because it's moving through the cooling system slower.
The ways radiators cool better are by being bigger and having more more water exposed to more surface area (and of course, by moving more air acorss it). I'm not understanding this one, unless dimpling is what they do for more surface area.
When you talk to the guy, get the company name so we can web search it. If it was a choice of restriction, I'd rather have more of the skinny passages that water flows through, as that would increase water-to-metal (to air) surface contact.
Re: Finally, new motor going in :) [Re: Wayne] #515306 03/05/05 06:27 AM
Jim_Paget Offline
The way that he explained it to me is that with straight tubes you are essentially the outer layer of the column of water. By introducing the dimples you are creating turbulence - essentially mixing the water so that more of the water molecules come in contact with the tubes.
Jim Paget
www.rrr4x4.com
Re: Finally, new motor going in :) [Re: Wayne] #515307 03/05/05 07:39 PM
houlster Offline OP
Isuzu Moderator
I'm not all that suspicious as the principal is sound. Laminar flow is great for low flow resistance, but it is not the best for heat transfer. Adding turbulence puts more water molecules in contact with the metal of the radiator as it flows though, aiding in heat transfer. Using a bigger radiator works essentially the same way, though it does it with more surface area rather than shuffling more water up against the existing surface area.
And I would like to see Jim's info, but please, if anybody (not picking on you Wayne, I mean anyone <img src="/forums/images/graemlins/wink.gif" alt="" />) wants to argue radiator theory, start a new thread for it???
--Dan
Re: Finally, new motor going in :) [Re: houlster] #515308 03/20/05 05:26 AM
houlster Offline OP
Isuzu Moderator
Been being lazy and working on the house so not a lot done. I did strip the interior and will spray it probably next weekend. I found 4 nice drain holes in the floor BTW that were plugged from the factory. They're the same size hole as the hole over the front body mount bolt so the rubber grommets for that will fit the drain holes.
I'm re-doing my shifters again, this time with the twin-sticks next to each other. I'm also building in a tray for the tranny shifter to sit in so it's not exposed underneath like it is now.
I did got the Isuzu radiator fan adapter/mount done. I was able to turn the pieces on my mini-lathe to a light press-fit so they stayed alligned for welding.
And, probably the best news yet is.... my IC/Adapter plate is done <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> It should ship Monday, so I should be able to bolt up my SC this week <img src="/forums/images/graemlins/nana.gif" alt="" />
Oh, also finished up my t-case re-build a few weeks ago and I added in some sight tubes this time too. Ain't it purdy smile
--Dan
Re: Finally, new motor going in :) [Re: houlster] #515309 03/20/05 10:43 PM
Rodeo Clown Offline
so what are the smaller white tubes on the D300 for?
1997 Isuzu Rodeo - Auto - 31" ATs
1995 Honda Passport - 1 tons - 39" Boggers
Re: Finally, new motor going in :) [Re: Rodeo Clown] #515310 03/21/05 01:22 AM
houlster Offline OP
Isuzu Moderator
Those are the vent lines for the D300 and the Klune.
I got my headers coated inside and out with ceramic coating from TechLine. I've used it 2 or 3 times before on my turbo manifolds and down-pipes. It does get dull with use, but it doesn't burn off or rust at least.
--Dan
Re: Finally, new motor going in :) [Re: houlster] #515311 03/21/05 01:42 AM
Daniel_T Offline
Looking good Dan... That t-case doubler realy turn out sweet. Thanks for the heads up on the 300. That is some smooth stuff you have been doing on your project. When do you forsee it to be done?
Keep up the great work,
Daniel
"Thanks for the joy that you gave to me"
Re: Finally, new motor going in :) [Re: houlster] #515312 03/30/05 02:20 AM
houlster Offline OP
Isuzu Moderator
warning: lots of pics....
woooohoooooo! hehe, just got IC/adapter plate today. I'm embarased to say how little I paid for it. Basically just material and shipping, all courtesy of our own member here 'wiguy'. He was able to use my drawing in the CNC shop he works at and do it on his own time. Major kudos to you wiguy <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> Thanks to OffRodEO too, for offering a backup to get it machined through a shop he deals with.
Here's a few pics:
Top and bottom plates.
They sandwich a 1.5" thick core for the IC. The half circle grooves in the two halves form the clamp for the hoses on the core when bolted together:
Similar deal with the port water injection nozzles. The nozzles press into the holes, pinching down the tube:
There is a hole and ports for PCV as well. On the stock SC, the PCV is part of the SC body. For the M112, I made provisions for it in the IC:
And finally:
[img]http://www.houlster.com/amigo/3800sc/IC/images/119_1954.jpg[/img]
[img]http://www.houlster.com/amigo/3800sc/IC/images/119_1955.jpg[/img]
Hope it fits under the hood <img src="/forums/images/graemlins/scared.gif" alt="" /> I am happy to say that the belt allignment looks good, and my drawing so far looks like it was nuts on for all the bolt holes and such but I'll find out later for sure. I did have to massage the core a little bit, but no biggie. The machining looks awesome on it too <img src="/forums/images/graemlins/smile.gif" alt="" />
Now I can get to work on moving the coil pack, making the fuel rails, mounting the 2nd A/C compressor (where the coil pack was) and relocating the alternator up and out to clear.
--Dan
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6648 MB (Peak: 0.7730 MB) Data Comp: Off Server Time: 2026-11-17 11:25:20 UTC
