Hooking up aftermarket oil pressure gauge #516372 10/21/04 02:03 PM
Okay, I think this has been hit on before, but I have an aftermarket oil pressure gauge that I want to hook up. The sender unit is 1/8" 27 tp, and of course the location that the oil pressure sender should go is a metric thread. I've read that I should tee it off and have both connected, but that sounds like its more trouble then its worth. I've found the adapters to attached the aftermarket sender, and would like to know how to fool the idiot light into thinking it has good pressure, as the factory sender is just a switch. I can't see the purpose of having both an idiot light and a gauge, the gauge provides far more information, and I think I'm just as likely to notice it as the idiot light.
Re: Hooking up aftermarket oil pressure gauge #516373 10/21/04 02:54 PM
fourwd1 Offline
If you have the adapters for the aftermarket sender, hook up the gauge and forget the IDIOT light. Hooking the light to the gauge sending unit will probably throw off the accuracy of the gauge, and since the light draws way more current than a gauge movement, it could possibly damage the sending unit.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: Hooking up aftermarket oil pressure gauge [Re: fourwd1] #516374 10/21/04 03:08 PM
Do I just leave the wire that went to it hanging?
Re: Hooking up aftermarket oil pressure gauge #516375 10/21/04 03:11 PM
ToyotaT Offline
What kind of gauge did you buy?
85 Toy Pickup
89 block 30 over and EB RV head/261 cam
Re: Hooking up aftermarket oil pressure gauge [Re: ToyotaT] #516376 10/21/04 03:50 PM
Its a no name electric gauge, just had to have something better than that light. I have a inkling that my oil pressure might be too low.
Re: Hooking up aftermarket oil pressure gauge #516377 10/21/04 04:31 PM
Also, anyone know the thread of the current oil pressure sensor on the block right now? I want to say its M12x1.25.
Re: Hooking up aftermarket oil pressure gauge #516378 10/21/04 05:28 PM
You should be able to unscrew the stock one and about 12" up there should be a plug that you can disconnect, then just tuck the remaining wire somewhere out of the way. That's all i did anyways, i have a mechanical gauge but it works great...very easy install and i actually had the right metric reducer for my application which was nice for a change.
Re: Hooking up aftermarket oil pressure gauge #516379 10/21/04 05:41 PM
I will do the same, thanks for the info!
Post deleted by little_joe #516380 10/21/04 05:54 PM
Re: Hooking up aftermarket oil pressure gauge #516381 10/21/04 05:58 PM
4Crawler Offline
You can also get a dual output sender, has both analog pressure output for a gauge and a contact output for an idiot light. I used a dual output VDO sender on my VW.
Oil pressure senders.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6200 MB (Peak: 0.7230 MB) Data Comp: Off Server Time: 2026-06-23 06:57:12 UTC
