body swap #519036 10/28/04 05:07 AM
P
prong Offline OP
hey all, my first post here.. this project is still in the planning stage pretty much but I cant resist posting some pics..
I am getting these for free, on the condition that I complete the swap:
one 91 trooper, 2.8 manual, meticulously maintained since new by my uncle, new bfg tires, warn hubs, engine in great shape, and bit of body damage
and one 90 trooper, 2.6 with a blown head gasket and automatic, from virginia (no rust), great interior
with these two combined, you'd be hard pressed to find a trooper in better shape here in minnesota..
what do you guys think?
1991 Trooper 2.8, 5spd - waiting for a different frame and tranny
1992 Rodeo 3.1, 5 spd - 1 inch between me and the headliner
Re: body swap [Re: prong] #519037 10/28/04 05:13 AM
Jim_Paget Offline
Looks like you are going to end up with a good Trooper, and a whole lot of saleable parts. Congratulations, and welcome to the board.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: body swap [Re: Jim_Paget] #519038 10/28/04 05:23 AM
N
NotSoSimple Offline
Lotsa work, but the ending product will be awesome!
Welcome, these guys will pull you out of all sorts of 'Zu Trouble I run into!
'90 Trooper - 2.6L 5-Speed - 1" BL - Custom Roof Rack+2x55watt ProComp - Herculined Interior - Pace Setter Header - Dynomax Super Turbo - K&N - ProComp ES3000 Shocks - Optima Red - MSD 6A - 31" Kumho Mudders - Black Rock Crawlers
Re: body swap [Re: prong] #519039 10/28/04 03:10 PM
Bansil Offline
Good luck and welcome aboard <img src="/forums/images/graemlins/cheers.gif" alt="" />
Bansil
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: body swap [Re: Bansil] #519040 10/28/04 04:46 PM
Rodeo Guy Offline
I say take that 91, sas it, chop the top, throw away the rest of the doors, and you will already have a good head start on trail damage. <img src="/forums/images/graemlins/shiner.gif" alt="" />
Seriously if it were me, I would first consider just fixing the 90. I don't know about the condition of the drivetrain or miles, but I would quicker change a head gasket than a whole body swap. And a lot of guys would argue that the 2.6 is just as good/better than the 2.8. I dunno maybe you are a master mechanic and have a garage with a lift available, body swap wouldn't be so bad for you. I know having this scene in my yard wouldn't go over too well with the homeowner's association...
Any in case, welcome and good luck on getting one of them troopers running!
Mike
"Damn the carnage! Full throttle ahead!"
95.5 rodeo, 37" Trxus MT, dana 44/9", coil-overs, lockers..... http://www.cardomain.com/memberpage/550454
Re: body swap [Re: Rodeo Guy] #519041 10/28/04 06:03 PM
P
prong Offline OP
Yeah, that would be awesome but im looking to get a daily driver out of this.. maybe I should save the unused body and engine and try to make something out of them..
Well, I am not much of a mechanic at all (trying to learn though), but I have people that can help me, access to a shop and tools, and free towing. The thing about the 2.8 is I know its been maintained well since new, and had the engine fixed up prior to a freak accident involving a garage ramp. The 2.6 on the other hand is sitting there with the head and everything removed, strewn about in the back of the vehicle, I dont know if the owner just gave up on it or found some more serious problem with the engine and got rid of it. I think the body swap is more doable for me, it will just take time, stripping out the bodies, wiring the engine back up, etc..
Re: body swap [Re: prong] #519042 10/28/04 10:17 PM
ShowMeDave Offline
Be prepared to swap most(or all) of the wiring harness. You've got it all so you are good to go.....just gonna be a LOT of work. You'll probably have to pull everything out from under the dash(heat/ac ducting) to get the under dash wiring out. I went thru basically the same thing just going from a standard tranny to an automatic. Welcome to the board and good luck on the swap!! <img src="/forums/images/graemlins/cheers.gif" alt="" />
David
?'90 Trooper?2.6L?Auto?DELTA Cam?AMC Head?"DN" Lift?SlakAzz Sliderzz
?TrXus M/T's?Black Rockcrawlers?Lockers by MIG & ARB?ProComp ES9000's
?Pics and junk...Thx Tad!!
Re: body swap [Re: ShowMeDave] #519043 10/29/04 12:11 AM
jdobbsj Offline
Cleaning up that block and putting a new head on the 2.6 will be WAY easier than the swap you are proposing. I'm all for it, but I'm just saying that the head issues on the 90 are not as tough to deal with as you might think. As I always say.... If I can do it, anyone can!!
Then you have your daily driver AND your trail rig..
JD
88 Pickup,4x4, 2.6 L, AMC head, K&N Air filter, Aisin Hubs, Redline Oils everywhere, 94 Trooper wheels.
Re: body swap [Re: jdobbsj] #519044 10/29/04 04:33 AM
P
prong Offline OP
I see what you mean, but I feel more comfortable with the body swap idea even though there is more time involved. I know I will have to rip out everything in the dash and deal with the wiring.. but id rather do that than try to put an engine back together right now.. Not scared of the 2.6 head issues but I know this 2.8 was well maintained. I could always keep them both and work on the 2.6 later, but will most likely just keep the frame for parts.
Re: body swap [Re: prong] #519045 11/02/04 05:28 AM
NATO308 Offline
Just curious, but why don't you just swap out the engine and transmission? Axles are easy, if you find a problem after the engine and transmission swap.
'94, and '00 Amigos and '00, 01 Rodeos. Rodeo springs and aftermarket 'hard top on 94. Aisin hubs OME 919's on the 2000 Amigo. 2000 and 2001 Rodeos have OME 912's and Aisin. Smoother ride with the OME 919's???
PHP: 7.4.33 Page Time: 8.117s Queries: 15 (0.003s) Memory: 0.6358 MB (Peak: 0.7471 MB) Data Comp: Off Server Time: 2026-06-23 13:06:42 UTC
