Replacing Oxygen sensor #519282 10/28/04 10:01 PM
sluggo Offline OP
Is replacing the Oxygen sensor as easy as it looks? Turn a couple nuts, disconnect the wiring harness and pull out the old oxygen sensor. Reverse procedure to install new one.
Re: Replacing Oxygen sensor [Re: sluggo] #519283 10/28/04 10:35 PM
surlynkid Offline
yup. the new OEM sensor comes with a new gasket. i'd buy two new nuts since they are a locking type.
nuts for oxy sensors (and for header piece drivers side) $1.48 90179-08059
if you have the right die, i'd clean up the threads on the studs and then use plenty of high temp (copper) anti-sieze.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Replacing Oxygen sensor [Re: surlynkid] #519284 10/29/04 02:47 PM
Nathan Offline
Chase the threads with a 8mm 1.25 die
1996 T100 Ext Cab 4x4 W/165k
AMSOIL Throughout
Re: Replacing Oxygen sensor [Re: Nathan] #519285 10/29/04 03:48 PM
sluggo Offline OP
The oxygen sensor is ordered from Underdog Racing, which I understand is a supporting member of this forum, for about $86 delivered. Can't beat that. Also went to the local Ace Hardward and picked up a couple 8mm w/ 1.25 pitch stainless steel nuts & lock washers and picked up some anti-seize (copper) from NAPA.
I don't have an 8mm 1.25 die for cleaning the threads. Do you think that is necessary or will a bronze bristle brush and some anti-seize be good enough?
Re: Replacing Oxygen sensor [Re: sluggo] #519286 10/29/04 04:08 PM
Nathan Offline
Depends on your rust factor. You could could always use a new bolt working it back and forth with some spray lubricant to clean the threads if you have to. You'll probably be fine.
AMSOIL Throughout
Re: Replacing Oxygen sensor [Re: Nathan] #519287 01/01/07 08:17 PM
NYT100 Offline
I replaced my 2 Oxygen sensors today. The nuts were starting to disintegrate, but came off very easily with a little PB Blaster.
Toyota part # for Front Sensor- 89465-39835
(actual number on part is 89465-35360 Denso# 7900)
Toyota part # for Rear Sensor- 89465-39735
(actual number on part is 89465-35320 Denso # 7760)
97 T100, 32" BFG/AT, Warn hubs, stock height with Bilstein shocks, Optima battery
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6080 MB (Peak: 0.6774 MB) Data Comp: Off Server Time: 2026-10-23 03:42:47 UTC
