Page 5 of 7 1 2 3 4 5 6 7
Re: Electric Forced Induction [Re: mlclark] #519573 11/01/04 02:15 PM
chasespeed Offline
I can also see the above mentioned roots electric, working, kinda...
BUT, a roots blower has rotors, which basically(being a loose explaination here...)thouch the side of the case, and as they spin, they create pressure(boost)...
I can only imagine the how this will affect the engine while its NOT running...
And as mentioned, you mention RPMs to spin that thing...
A street 6-71 blower, is usually run at a 15-5 % underdrive.. which isnt much slower than the motor turns..
And a started will not work well after more than 15-30 seconds of continuous cranking..
My 2 cents
Chase
Chase
Re: Electric Forced Induction [Re: mlclark] #519574 11/03/04 05:30 AM
Chris Perosi Offline
Isuzu Staffer Emeritus
That was not my intention. If I came across like that, it was purely by accident.
Nope, it didn't -- that particular comment was not directed at you -- you never said anything about my acceptance or knowledge of the laws of physics... (except good-natured ribbing, but that's always all good). I merely mentioned it in passing like I did so as to not start anything unnecessarily.
Anyway, let me give you the 3rd grade answer to this question that I asked for additional clarity on, so all can understand (tho you really did a pretty good job of explaining without getting too complex) ---
Q: How does the alternator drain horsepower due to more electrical draw on the battery?
A: Inside the alternator, there is a regulator which adjusts how much electrical power the alternator can make. As more power is required from the alternator, the magnetic field inside it gets stronger, causing the alternator itself to be harder and harder to turn. This, in turn, draws more and more on the engine due to the fact that the engine has to work harder to turn the alternator.
Believe me, I liked all the complexity and the technological answers and stuff... But this is the simple answer -- the electromagnetic field in the alternator grows stronger and stronger, making it harder to turn. Correct me if I'm wrong, tho...
-Chris
Chris Perosi
Isuzu Editor Emeritus
OutdoorWire, Inc.
Re: Electric Forced Induction [Re: mlclark] #519575 11/03/04 07:59 AM
strawmyers Offline
Isuzu Moderator
I can also explain how your kidneys work,
Now you're stepping onto my territory........ explain away, I want to see how you do <img src="/forums/images/graemlins/pfft.gif" alt="" />
Sean Strawmyer
Re: Electric Forced Induction [Re: strawmyers] #519576 11/03/04 09:54 AM
mlclark Offline
Isuzu Moderator
You gotta be careful, my territory is vast.
Kidneys. Approximately 20% of all cardiac output is in the kidneys during an average time. Times of stress or illness changes this number, but the kidneys are very highly vascularized organs.
Blood flowing into the kidney is still in the arterial side of the cardiovascular system. It flows into an arterial capillary structure, called a gloumerulus. The gloumerulus is fed by an afferent arteriole and blood exits via an efferent arteriole. The gloumerulus is a capillary, but not in the traditional sense of a zone of exchange where the blood flows from the arterial side of the system and enters the venous side. It has to be arterial because it is a very high pressure structure that literally filters the blood of water, ions, some proteins and nitrogenous waste products, along with some hormones and other metabolites. This filtration is so effective that both kidneys are able to filter 125ml of filtrate per min, or about 45 gallons a day from the blood. 45 gallons a day all day, every day for your life. No kidding.
The gloumerulus is surrounded by Bowman's capsule. Bowman's capsule is the beginning of the tubular component of the functional unit of the kidney, the nephron. We have already talked about the vascular component, the gloumerulus. Bowman's capsule drains into the proximal convoluted tubule, which feeds into the loop of Henle and finally into the distal convoluted tubule and empties into the collecting duct which then eventually ends up in your bladder and beyond. In the proximal tubule, the body is able to reabsorb larger molecules, like proteins and amino acids, glucose, vitamins and fatty acids. Once these molecules are actively transported out, water follows out because there is an osmotic gradient created. The efferent arteriole from the gloumerulus encircles the convoluted tubule to receive these substances and to also later deliver hormones to the kidney. The remaining filtrate continues through the tubular component. Water is absorbed in the loop of Henle, solutes (ions, mostly) are absorbed in the near distal tubule, more water is absorbed through the rest of the tubule and the collecting duct. Secretion happens in the late distal tubule. Luckily, only 1% of that filtrate makes it to urine. So, .5 gallons a day is about what you have to get rid of.
Now, it is not over. What controls this? Well, is physically controlled by blood flow and pressure in the gloumerulus. Lower pressure or lower flow means lower filtration rate. It is also somewhat controlled by the composition of the blood. Your body can filter and reabsorb only so much before it shows up in the urine. For example, both kidneys see about 600 mg of glucose per minute in the blood. Of that, about 25% is filtered out. So, about 150mg/min enters the kidney and none of enters the urine because it is all transported back into the blood stream. In diabetics, their glucose level is so high, the kidney is unable to force it all back into the blood. Way back when, diabetes mellitus (Type 1) was diagnosed by the sugar crystals on mens' shoes. Want to test your threshold? Eat about a pound of sugar and start tasting your urine. When it tastes sweet, you know your kidneys have been overwhelmed.
But back to control. Control is hormonal. Vasopressin is secreted by the hypothalamus and stored in the posterior pituitary. When released it has two main effects. It causes constriction of the afferent (in) arteriole and this slows down the filtration rate, conserving water. It also binds receptors in the tubular system to open aquaporins that allow for water reabsorption. Again, conserving water. Vasopressin is released when low blood pressure is sensed by baroreceptors in the carotid arteries and the right atrium of the heart. Low blood pressure can be indicative of dehydration or blood loss. Protein or solute concentration of the blood also controls the release of vasopressin. Low protein caused by liver insufficiency or malnutrition will cause the body to move water from the blood to the interstitial space outside of the cardiac system. In that case, the body needs to conserve water to maintain pressure, blood volume and blood composition. Diabetes insipidus is when there is a lack of vasopressin production from the endocrine system or an insufficiency of receptors. In that case, water is not reabsorbed, but it is forced out of the body in vast quantities. Polydipisa/Polyuria are signs of Type 2 diabetes. Large amounts of water are consumed and large amounts of urine are produced. Wanna test for it? Taste the urine. It is so dilute, it has no taste. Again, olde time diagnostics.
HowÆd I do, Sean? <img src="/forums/images/graemlins/smile.gif" alt="" />
Michael
Re: Electric Forced Induction [Re: mlclark] #519577 11/03/04 01:28 PM
strawmyers Offline
Isuzu Moderator
Approximately 20% of all cardiac output is in the kidneys ..... 45 gallons a day .... only 1% of that filtrate makes it to urine. So, .5 gallons a day is about what you have to get rid of....... kidneys see about 600 mg of glucose per minute in the blood.......25% is filtered out.......150mg/min enters the kidney
Michael
The information is good <img src="/forums/images/graemlins/kewl.gif" alt="" />....... if not a little too good/complete/organized to be pulled completely out of the back of your mind without at least a quick scan of some kind of reference source. I don't see where you cited any sources though...... so I have no choice but to suspect some kind of academic misconduct <img src="/forums/images/graemlins/nana.gif" alt="" />
Sean Strawmyer
Re: Electric Forced Induction [Re: strawmyers] #519578 11/03/04 03:11 PM
litnin Offline
Knowledge is not always knowing exactly how something works. It's more being able to figure out how something works and knowing where to go to find out the information you are looking for... A broad idea of how something works can be clarified much by research.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: Electric Forced Induction [Re: strawmyers] #519579 11/03/04 04:00 PM
mlclark Offline
Isuzu Moderator
Belive it or not, all I scanned were some class notes of mine. The actual numbers were what I needed. As Litin said, understanding it is part of of the game, the rest is knowing where to find the information. Nothing above is cut and pasted, it is all mine. As I said, my territory is broad. <img src="/forums/images/graemlins/smile.gif" alt="" />
Michael
Re: Electric Forced Induction [Re: mlclark] #519580 11/03/04 05:07 PM
O
OffRodEO Offline
Wow, i didnt know my truck had kidneys. Maybe thats why he doesnt have the power like he use to. Anyone wanna donate a kidney from their rigs? My guy is sick and is on his last kidney. <img src="/forums/images/graemlins/nana.gif" alt="" />
kevan <img src="/forums/images/graemlins/lol.gif" alt="" />
93 rodeo,3.2 manual, limo tint, nice sound system,keyless entry and a killer alarm, drop in K&N, 3 inch DOR lift, 32-11.50 BFG MT's, warn hubs zutah.com wheeler
WELLS FARGO BANK WILL RIP YOU OFF!GET OUT WHILE YOU CAN
Re: Electric Forced Induction [Re: litnin] #519581 11/03/04 08:50 PM
strawmyers Offline
Isuzu Moderator
I know, bud..... just giving Michael a hard time. Somewhere along the path to being at the top of my graduate program, I've gathered a bit as to what knowledge is. <img src="/forums/images/graemlins/wink.gif" alt="" /> And working in the medical field, we have to be just as good at hunting down information as remembering it. Michael is a smart guy, no doubt about that in my mind..... that's why I implied he quickly scanned a reference instead of implying he did a copy and paste job. I wouldn't expect anything less out of an engineer <-- running joke <img src="/forums/images/graemlins/smile.gif" alt="" />
OffRodEO~ no kidneys on our trucks, sorry to get your hopes up.
Sean Strawmyer
Re: Electric Forced Induction [Re: strawmyers] #519582 11/03/04 09:27 PM
Michael, with all that amazing array of knowledge in your head, donchya think we can come up with some other way of diagnosing problems with the kidneys, shy of tasting the urine? <img src="/forums/images/graemlins/barf.gif" alt="" /> I mean, really, for a smart guy, you sure like to go around drinking urine. Not sure how smart that is -- although I bet you could tell me. <img src="/forums/images/graemlins/notooth.gif" alt="" /> Everyone just watch out in Moab when Michael offers you a beer around the campfire -- never know what you're gonna get.
Chris Perosi
OutdoorWire, Inc.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6564 MB (Peak: 0.7761 MB) Data Comp: Off Server Time: 2026-06-10 01:41:07 UTC
