Page 2 of 3 1 2 3
Re: Good place to pick up gears? [Re: Ganoid] #519723 10/31/04 05:46 PM
fantastic info man. Now onto install...i assume it's not "that" hard as actually changing out the pinion and ring correct? Anybody have a picture of what we'd actually get that way i can imagine exactly what it is?
Re: Good place to pick up gears? #519724 11/01/04 03:28 PM
superv43 Offline
And for those who may decide to have your existing third member regeared, try Reider Racing
They use Precision gears and their price for setup was cheaper than anyplace locally when I last looked ($100 labor) They also have very good prices on lockers/lsd.
I sent them a worn out third member a while back, for around $650 they put in a Detroit TruTrac (~$270), new Precision ring/pinion V6 gears (~$180), new bearings (~$100), setup labor (~$100)
(these prices are from memory, I can probably dig up the reciept if anyone wants more detail)
Greg
Re: Good place to pick up gears? #519725 11/01/04 03:45 PM
superv43 Offline
Rear third swaps are pretty easy. This tech article has some good detail on third member removal/installation.
4x4Wire LockRight Install
The front can be more work, especially with IFS trucks. fwiw - The Tacoma front diff swap I did recently was actually not bad at all.
Greg
Re: Good place to pick up gears? #519726 11/02/04 06:47 PM
Nix_Toy Offline
Ok, I have two questions.. one, what is ABS? I always thought that just mean anit lock brake system, and also, when you're buying the carrier, are they shipping the whole axle?
Thanks,
-Nick
Re: Good place to pick up gears? [Re: Staceman] #519727 11/03/04 03:44 AM
dildinon Offline
somebody correct me if im wrong but arent the factory 8" 4.88s oddball? the gears wont work in other diffs and the diffs wont take normal gears?
Davin Nisser
'94 Pickup Xtra Cab Deluxe 3.0 V6 5spd...'84 lwb frame swap with 2" body/drive train lift and solid axle in the works...
Re: Good place to pick up gears? [Re: dildinon] #519728 11/03/04 05:31 AM
Ganoid Offline
The ABS for a third just means it has a ring gear sensor for knowing if the wheels are still moving. If you dont have ABS just dont hook it up and all will be good.
As far as the 4.88's being weird yes thay are but its not like your giving up your current thirds. If the 4.88's ever fail you just buy another 4.88 third or have your current ones regeared. You cant regear the factory 4.88's from what I understand. How many factory toyota gear sets fail when properly maintained? I honestly dont know?
r6elmo... you dont have the change the ring and pinion individually just pull the axles out and remove the whole third as a single unit and replace it. There really is no "set up" involved just swapping.
90 Xcab V6
3.0 Rebuilt/Balanced
P/P w/OS valves
Downey Hdrs,Jacobs Ign
5.29's,Tru Trac+Lockright
4"TG SAS+Rear Kit on 35's
(DOA Racing = $1200 lesson <img src="/forums/images/graemlins/angry.gif" alt="" />)
www.performancecylinderheads.com
Re: Good place to pick up gears? #519729 11/03/04 03:45 PM
Nix_Toy Offline
Ok.. so the 4:88 will be a direct bolt on in an 85 front and rear without any kind of modification? Just want to get this straight, because thats an awesome deal.
Re: Good place to pick up gears? [Re: Nix_Toy] #519730 11/03/04 04:06 PM
Dok Offline
Yup, they'll bolt right in. I recently found out the factory 4.88's will work with all of the locker options as well. I have a factory 4.88 diff sourced off of car-part as well. I was lucky and found mine at a local yard for $200, paid a little more but I got to check it out first. Took me about 2 hours to swap 'em in working slowly <img src="/forums/images/graemlins/kewl.gif" alt="" /> The front isn't really that bad, you can usually just unbolt the cv's and the diff mounts and drop it out without pulling anything else. Might be a good time to get rid of the press fit studs for the cv's as well. Just be careful, I was maneuvering my old diff out and I almost dropped it on my head <img src="/forums/images/graemlins/drunk.gif" alt="" />
'87 4-Runner--DD/wheeler, 4.3 swap coming soon
'89 Supra--E85 powered 2jz NA-T Swap, 533rwhp 497ft-lbs
'89 Festiva, turboed BP swap powered by megasquirt
Re: Good place to pick up gears? [Re: Ganoid] #519731 11/03/04 11:51 PM
It almost sounds too good to be true! I havent had a single thing on this build up go smooth <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: Good place to pick up gears? #519732 11/04/04 05:14 AM
Staceman Offline
All is cool fellas. I'm tellin' you, just search for the "carrier/see also differential" for your V6, 4.88 factory geared third members. ABS equipped is OK, in fact, both my front and rear's are set up with this. Obviously, my '85 4Runner is not ABS. All it is is a magnetic pick-up sensor that sits on top of the housing, with the magnet placed close to the ring gear. Just cut the cable at the diff connection, leaving the sensor in place. It won't do anything, and it plugs the hole for you. With the set-up labor I didn't need to pay for, I bought a used Supra LSD diff to put the LSD guts into my rear 3rd, and a lock-right to put into the front. I'm telling you, going from open 4.10 and 33" tires, to 4.88, LSD rear, lock-rite in front (only engaged when hubs are locked), it is an entirely different truck!!! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6371 MB (Peak: 0.7439 MB) Data Comp: Off Server Time: 2026-06-21 18:50:15 UTC
