Page 3 of 3 1 2 3
Re: Good place to pick up gears? [Re: Staceman] #519733 11/04/04 05:18 AM
Staceman Offline
Before I forget. Make sure you tell the guys at the yard you buy them from to COUNT THE TEETH. I had to send back a beautiful 4.56 assembly and wait for the 4.88. 39 ring gear teeth, 8 pinion teeth. I have a feeling that the prices will be going up on these if everyone sells out at once!
Re: Good place to pick up gears? [Re: Staceman] #519734 11/04/04 06:02 AM
Dok Offline
Good thing I already got mine <img src="/forums/images/graemlins/kewl.gif" alt="" /> How does your rig steer with that lockrite in the front when you're in 4wd?
'87 4-Runner--DD/wheeler, 4.3 swap coming soon
'89 Supra--E85 powered 2jz NA-T Swap, 533rwhp 497ft-lbs
'89 Festiva, turboed BP swap powered by megasquirt
Re: Good place to pick up gears? [Re: Dok] #519735 11/04/04 11:05 PM
Staceman Offline
Good question. On the trail, it never dis-engages. It's always locked. The wheel is harder to turn physically, but not too bad. You gotta turn the wheel farther to get through a "hair-pin" turn, but overall, not bad. With what is gained on the trail with the front locked, the steering is no biggie. It's easier to adjust to the steering, than really getting used to saying, "yeah, no problem, I'll meet you at the top, you better take this "sissy" route.
Re: Good place to pick up gears? [Re: Staceman] #519736 11/05/04 03:10 AM
OK, maybe Im not doing the search correctly. But, Im trying to figure out what all the differences are in these things. I did the search on the front axle and I got back the first page showing prices of $1100.00 all the way down to $90.00. BIG difference. So, how do I know if Im looking at the right thing? Some say for auto, is there a difference? The front search option say with auto disconnecting diff? Honestly, I dont want to dump money on the wrong part and Salvage yard people talk to you like your a dumbass if you dont know the answers to their questions.
Re: Good place to pick up gears? #519737 11/05/04 05:04 AM
Dok Offline
Make sure you search for "carrier" not front or rear axle unless you want the whole shebang. You can use either the regular or auto disconnecting diff, you just may have to pull some uneccesary stuff off of it, no biggie. So, to summarize:
You need to search for a "carrier" for a '92-'95 Truck or 4Runner, should be anywhere from $150-$250, any more or less and be skeptical.
Re: Good place to pick up gears? [Re: Dok] #519738 11/05/04 05:37 AM
So the auto disconnecting diff, is that like limited slip or...?
"I have a feeling that the prices will be going up on these if everyone sells out at once!"-Staceman
SHHHH! Lets keep this one to ourselves for a couple weeks. <img src="/forums/images/graemlins/evil.gif" alt="" />
Re: Good place to pick up gears? #519739 11/05/04 06:05 AM
Dok Offline
Nope, ADD is the automatic locking system for 4wd used instead of manual hubs or auto locking hubs.
Re: Good place to pick up gears? [Re: Dok] #519740 11/05/04 04:37 PM
OK, now Im confused. Do I want these or not?
Re: Good place to pick up gears? #519741 11/07/04 12:44 AM
Staceman Offline
You can get the ADD set-up. Usually more abundant and cheaper anyways. If you do get these, and you already have manual (dial) locking front wheels, do THIS to the diff before you install. <img src="/forums/images/graemlins/coolg.gif" alt="" />
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6273 MB (Peak: 0.7299 MB) Data Comp: Off Server Time: 2026-06-21 20:21:49 UTC
