Page 3 of 11 1 2 3 4 5 … 10 11
Re: Reminding Vendors of the Power of this Board -- BRAINSTORMING NEW PRODUCTS [Re: sweater] #520170 11/01/04 02:24 AM
strawmyers Offline
Isuzu Moderator
[*] Front diff drop brackets for IFS to deal with increased CV angles
<img src="/forums/images/graemlins/confused.gif" alt="" /> Got'em <img src="/forums/images/graemlins/confused.gif" alt="" />
Sean Strawmyer
Re: Reminding Vendors of the Power of this Board -- BRAINSTORMING NEW PRODUCTS [Re: strawmyers] #520171 11/01/04 04:39 AM
Sammy Offline
I'll second (or third) the vote for the 3.2 alternator reloction brackets -- if that's something that's even feasible. Not much room to play with under there.
The "smurfed" cv joints along with Joe's diff drop should take care of most of the weak IFS parts (yes, Travis Rankin is still around and making 'em). That said, it would still be nice to have something with a little more girth made of stronger materials.
And...How about tie rods? What happened to the Stinkyfabs?
Sammy
95.5 Rodeo, automatic, 3.2 SOHC, D44 front and rear, 4.88's, 33" muds
Re: Reminding Vendors of the Power of this Board -- BRAINSTORMING NEW PRODUCTS [Re: Sammy] #520172 11/01/04 09:26 AM
StinkBug Offline
Noticed someone lookin for quick release door hinges above. I'd love to make em for you and make some money, but the truth is you already have em on your rig, you just need to take the hinges off, cut/grind/drill out the stock hinge pins, drill the hinge halfs to 3/8". Bolt each half back to the truck/door, line em up and drop in some 3/8" clevis pins from home depot. Total cost under $10 and about 2 hours of time.
As for the Tie Rods, I've got the prototypes finished, but am still working with a couple vendors to get things rolling. There will be an official announcement when they are ready.
Dallas
[color:"blue"]Crew Chief, RedBull RockCrawling Team [/color]
[color:"red"]StinkyFab Custom Metal Creations[/color]
Project StinkBug
Re: Reminding Vendors of the Power of this Board -- BRAINSTORMING NEW PRODUCTS [Re: StinkBug] #520173 11/01/04 03:37 PM
jezeric Offline
Isuzu Moderator
A replacement tranny crossmember for the 0G Troopers that doesn't stick out past the frame into big-tire-land?
James
Re: Reminding Vendors of the Power of this Board -- BRAINSTORMING NEW PRODUCTS [Re: randii] #520174 11/01/04 03:55 PM
sweater Offline
[*] Twinstick, dual transfer case adapter, or any transfer case adapter to get towards a more regearable/flexible transfer case. $750's good for a set of TeraLows, but give me a $50 junkyard pull of a Dana 300 or equiv. any day. (I know - the spline counts might not match, but I'm high on possibilities here)
[*] Mass-produced (read: cheap) Isuzu tcase flange adapters for CV driveshafts. These normally run you $100 apiece, but probably could be cheaper.
Re: Reminding Vendors of the Power of this Board -- BRAINSTORMING NEW PRODUCTS [Re: sweater] #520175 11/01/04 04:18 PM
4WDJOE Offline
Outed ya Matt <img src="/forums/images/graemlins/smile.gif" alt="" />
http://www.pirate4x4.com/forum/showthread.php?t=295153
97 Rodeo
Re: Reminding Vendors of the Power of this Board -- BRAINSTORMING NEW PRODUCTS [Re: sweater] #520176 11/01/04 06:02 PM
P
pplotz Offline
Bigger Gas tank!!!
I'm sick of my (now) 14 gallon tank!
Re: Reminding Vendors of the Power of this Board -- BRAINSTORMING NEW PRODUCTS [Re: pplotz] #520177 11/01/04 06:30 PM
slappy Offline
How about a tire rack swing gate for those of us with an underneath mounted spare?
And it could be tied into a rear bumper as well... <img src="/forums/images/graemlins/notooth.gif" alt="" />
-john
99 Rodeo 3.2L 4WD
Re: Reminding Vendors of the Power of this Board -- BRAINSTORMING NEW PRODUCTS [Re: randii] #520178 11/01/04 06:40 PM
Pyro4117 Offline
Headers for the 2.8/3.1/3.4 V-6's that will fit Isuzu products.
Resurrect the ARB bumper for the first Gen Troopers.
Pre-made modified MUA-5 shifters to work with body lifts.
Body lifts in 1" increments.
Polyurethane replacement body mounts and suspension bushing kits.
Along with the 4.77 gears, how about the 5.13's supposedly available for the overseas diesel trucks.
Replacement speedometer gears to match axle gear changes (and or an electronic programmable unit).
Another vote for the fender flares.
Speaker mount kits that duplicate that factory above-the-rear-door mounts in some Troopers.
Jay
1991 Trooper - DEAD! 2.8 V6, 5 spd, 4WD, HD clutch, 2.25" exhaust, EPROM Chip, KC/Hella, Aisin hubs, Rancho 9000X's, Panasonic/Infinity/Alpine
My Pics
Re: Reminding Vendors of the Power of this Board -- BRAINSTORMING NEW PRODUCTS [Re: Pyro4117] #520179 11/01/04 07:14 PM
P
pplotz Offline
http://www.4x4mountainsport.com has 5.13's and a speedo gear that can adjust to many different tire sizes.
PHP: 7.4.33 Page Time: 0.022s Queries: 16 (0.019s) Memory: 0.6523 MB (Peak: 0.7734 MB) Data Comp: Off Server Time: 2026-11-19 17:14:28 UTC
