00 4runner clutch time....suggestions?
#521611
11/03/04 06:36 PM
Although the clutch on my runner is in decent shape the throwout bearing is getting louder and louder and in stop and go traffic it is annoying. So with 95k miles I decided its time to do the clutch anyway.
I know there are many different clutches out there...centerforce, oem, TRD. What do you use? Complaints? Cost? Suggestions?
I use my runner as a dd and offroad about 7 or 8 times a year. I also tow a small motorcycle trailer occasionally.
Thanks, Mike
Re: 00 4runner clutch time....suggestions?
#521612
11/04/04 03:09 AM
I went with all Toyota OEM replacement parts. Had to replace the fly-wheel as well. Seems there was too many full thickness cracks in it to just re-surface it.
If you are planning on headers, then would be the time to do as the rear of the engine is open. Thus the cross-over pipe is easy access. Also, I'd recommend replacing the rear seal at the same time - $20 for the part - 5 minutes to replace with the tranny disconnected.
Just a few thoughts. Andrew
Duty is the sublimest word in the English language.
'96 SR5 4x4 5sp, ARB Prado Bull Bar, PP 1 Springs & Bils, Deck Plate, Hella 550s, PIAAs Volvo '97 850 GLT - Sublime Rice Killer
[Re: WatsonMD]
#521613
11/04/04 05:14 AM
Good call on the rear seal. Do you remember how much OEM was? I want to compare to aftermarket.
#521614
11/04/04 01:36 PM
Can't remember off the top of my head. I picked them all up from Concelli Toyota. They have an online parts directory that is fairly easy to browse. Andrew
#521615
11/04/04 10:54 PM
#521616
12/21/04 06:40 AM
Ok I am giving myself a shameless bump on this one because I called the dealership and a clutch assy is gonna run me $442.00. That is quite a bit more than I was planning to pay especially around the holidays.
That being said I noticed Marlin Crawler sells a clutch for $299.00 Has anyone tried this clutch or Should I just quit my complaining, stick with OEM, and take it in the <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
The clutch is starting to slip and I don't want to drive it any more than I have to. (heat = warpage and cracks!)
Any other clutch brand experiences are appreciated. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Thanks,
#521617
12/21/04 07:31 AM
shop around on that clutch.....I got a toyota remanufactured clutch, disk and a new bearing and the whole thing was $350. I got it through ORS in Arvada, CO.....not a toyota Stealerhip though
'93 4Runner - 3.4L 5VZ-FE, 2" body lift, on-board-air system, custom gauge cluster, rear e-locker, electric fan, custom built front and rear bumpers, sliders, 4,88 gears...all on 33x12.5's.
[Re: CORunner93]
#521618
12/23/04 04:38 AM
I would use a ASCO clutch same as OEM new ,and a lot less money . Who is doing the labor ? Hey I think we're neighbors
#521619
12/23/04 04:50 AM
I looked at the ASCO but hadn't heard an oppinion on them. Yes we are neighbors!!! There are actually a few of us on the wire that live in this area. Maybe we can all get together for some local wheeling?!
As for the labor...its all me.
#521620
12/23/04 06:02 AM
ASCO (Aisin Seiko Corporation) is the manufacturer for stock Toyota clutches. You can get them cheap from www.jtoufitters.com call and ask for Joe, tell him you want the ASCO clutch.
