00 4runner clutch time....suggestions? #521611 11/03/04 06:36 PM
Although the clutch on my runner is in decent shape the throwout bearing is getting louder and louder and in stop and go traffic it is annoying. So with 95k miles I decided its time to do the clutch anyway.
I know there are many different clutches out there...centerforce, oem, TRD.
What do you use?
Complaints?
Cost?
Suggestions?
I use my runner as a dd and offroad about 7 or 8 times a year. I also tow a small motorcycle trailer occasionally.
Thanks,
Mike
Re: 00 4runner clutch time....suggestions? #521612 11/04/04 03:09 AM
WatsonMD Offline
I went with all Toyota OEM replacement parts. Had to replace the fly-wheel as well. Seems there was too many full thickness cracks in it to just re-surface it.
If you are planning on headers, then would be the time to do as the rear of the engine is open. Thus the cross-over pipe is easy access. Also, I'd recommend replacing the rear seal at the same time - $20 for the part - 5 minutes to replace with the tranny disconnected.
Just a few thoughts.
Andrew
Duty is the sublimest word in the English language.
'96 SR5 4x4 5sp, ARB Prado Bull Bar, PP 1 Springs & Bils, Deck Plate, Hella 550s, PIAAs
Volvo '97 850 GLT - Sublime Rice Killer
Re: 00 4runner clutch time....suggestions? [Re: WatsonMD] #521613 11/04/04 05:14 AM
Good call on the rear seal. Do you remember how much OEM was? I want to compare to aftermarket.
Re: 00 4runner clutch time....suggestions? #521614 11/04/04 01:36 PM
WatsonMD Offline
Can't remember off the top of my head. I picked them all up from Concelli Toyota. They have an online parts directory that is fairly easy to browse.
Andrew
Re: 00 4runner clutch time....suggestions? #521615 11/04/04 10:54 PM
Anyone ever try an Exedy clutch kit?
Clutch Kit
I2030-104320
http://oem.thepartsbin.com/parts/th...amp;category=All&part=Clutch+Kit
Re: 00 4runner clutch time....suggestions? #521616 12/21/04 06:40 AM
Ok I am giving myself a shameless bump on this one because I called the dealership and a clutch assy is gonna run me $442.00. That is quite a bit more than I was planning to pay especially around the holidays.
That being said I noticed Marlin Crawler sells a clutch for $299.00 Has anyone tried this clutch or Should I just quit my complaining, stick with OEM, and take it in the <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
The clutch is starting to slip and I don't want to drive it any more than I have to. (heat = warpage and cracks!)
Any other clutch brand experiences are appreciated. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Thanks,
Re: 00 4runner clutch time....suggestions? #521617 12/21/04 07:31 AM
CORunner93 Offline
shop around on that clutch.....I got a toyota remanufactured clutch, disk and a new bearing and the whole thing was $350. I got it through ORS in Arvada, CO.....not a toyota Stealerhip though
'93 4Runner - 3.4L 5VZ-FE, 2" body lift, on-board-air system, custom gauge cluster, rear e-locker, electric fan, custom built front and rear bumpers, sliders, 4,88 gears...all on 33x12.5's.
Re: 00 4runner clutch time....suggestions? [Re: CORunner93] #521618 12/23/04 04:38 AM
I would use a ASCO clutch same as OEM new ,and a lot less money . Who is doing the labor ? Hey I think we're neighbors
Re: 00 4runner clutch time....suggestions? #521619 12/23/04 04:50 AM
I looked at the ASCO but hadn't heard an oppinion on them. Yes we are neighbors!!! There are actually a few of us on the wire that live in this area. Maybe we can all get together for some local wheeling?!
As for the labor...its all me.
Re: 00 4runner clutch time....suggestions? #521620 12/23/04 06:02 AM
Adam F Offline
ASCO (Aisin Seiko Corporation) is the manufacturer for stock Toyota clutches. You can get them cheap from www.jtoufitters.com call and ask for Joe, tell him you want the ASCO clutch.
97 4R, stock, daily driver
PHP: 7.4.33 Page Time: 1.529s Queries: 16 (0.003s) Memory: 0.6291 MB (Peak: 0.7466 MB) Data Comp: Off Server Time: 2026-06-05 20:56:25 UTC
