Injector O-rings... Toyota?
#522996
11/07/04 06:12 PM
Ok, so the heads are off, machined and waiting for the gaskets to come in.
Now on to the injectors, this is my DD so I do not have time to send away the injectors. I need to get new o-rings for them before I put it all back together. The manual (online autozone) says to replace the grometts and insulators along w/ the o-rings. All of this from Toyota is $140. Seems a little steep for 18 o-rings, 6 grometts and 6 insulators.
The question...
can I reuse the grometts and insulators, and where can I get o-rings besides toyota? None of the parts stores have the o-rings listed, so does anyone know the specific sizes needed?
95 3vze 165,000 miles.
Thanks again!!!!
Anthony
Re: Injector O-rings... Toyota?
[Re: wave]
#522997
11/07/04 06:25 PM
I changed my friends Tacoma injectors to the URD type.It had new O rings and I used the other parts from the old injector to complete assembly.Make sure they are in excellent shape.
88 4x4 22re 86 2wd 1-ton 22re 91 2wd 22re
[Re: wave]
#522998
11/08/04 02:06 AM
they are avaliable aftermarket ... I just got mine done $100.00 CDN including orings and insulators , mind you its for a 4cyl . ![[Linked Image]](http://www.members.shaw.ca/slacker502/images/injectors.JPG) sorry for the blurry image .
[Re: wave]
#522999
11/08/04 03:09 AM
Depending on where you are at, you should be able to have the injectors cleaned and/or rebuilt locally, or within driving distance.
[Re: Snowtoy]
#523000
11/08/04 04:08 AM
I think i have 6 injector "insulators" avail, new. I ended up over buying 6 of them. As for the O rings on the top of the injectors.. no idea. If you are interested, let me know.
94runner: Dana 44 SAS, 35's, Lockers, gears, winch, rock rails, bumpers, 3"BL, drivetrain lift, Budbuilt cross member, centerforce clutch and MORE! ***FOR SALE*** $8,500 -1985 Supra (STOCK!) FOR SALE $4,000 www.celicasupra.com
[Re: wave]
#523001
11/08/04 04:04 PM
NWOR sells the kit you are looking for. It includes all the o-rings, insulators, grommets, copper washers for fuel delivery lines as well as a throttle body gasket for $25.
Give them a call.
