Check engine light #523971 11/09/04 09:20 PM
juggernaut Offline OP
Also my check engine or egr light is on. Is ther an easy way to pull the codes on these Raiders? I would assume that the brains on these things are that high tech.
2001 Jeep Wrangler Sahara/4" Rough Country Lift/BFG 32x11.5x15
I caught this "JEEP thing" of your and now it hurts when I pee.
Re: Check engine light [Re: juggernaut] #523972 11/10/04 12:02 AM
LRJ4x4 Offline
The codes are pulled with a old analog voltmeter. You count the times the needle swings back and forth. I think there is a write up in the archives.
Re: Check engine light [Re: juggernaut] #523973 11/10/04 01:39 AM
1991monterols Offline
go to the main mitsubishi section and go to the tech articles
1991 Montero LS 5sp with 32s on black 15x8, snorkle, roof rack, 9000lb milemarker, cb, 4 hella lights sold
1991 Montero RS Auto on 35s, 2in BL, hella lights, cb, roof rack blown headgasket
Re: Check engine light [Re: juggernaut] #523974 11/10/04 03:06 AM
LandRaider Offline
I would imagine you hit the "every 50k service light"
There is a switch behind the guages to shut it off. Nothing high tech about it.
Re: Check engine light [Re: LandRaider] #523975 11/10/04 11:09 PM
I guess I missed it. Looking at tech on front page but nothing about check egr or error codes. Thanks for helping the noob.
Re: Check engine light [Re: juggernaut] #523976 11/11/04 12:55 AM
DaphneD Offline
I believe someone has previously made the distinction between the "check engine" light and the "maintenance required" light. The latter can be turned off by pressing a button (do a serch). The former can indicate a multitude of sensor/performance malfunctions.
If the "check engine" light is coming on, try clicking here.
-DougB <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Check engine light [Re: DaphneD] #523977 11/11/04 01:04 AM
PHIL_ Offline
But his sig say 87 Dodge Raider. My article is for the fuel injected v6. Isn't the only computerized component inside the dizzy on a 4 banger?
PHIL
Re: Check engine light [Re: PHIL_] #523978 11/11/04 05:38 AM
Thanks and it is the check egr light. I was thinking of jeep with the ckeck engine light. Sorry for confusion.
4 banger computer [Re: PHIL_] #523979 11/11/04 11:03 PM
TobyB Offline
no, there's an ecu on the 4 cyl with carb. That drove me nuts- the carb does most of the work, but the computer and o2 sensor fine- tune the mix with a mini- injector to compensate for changing conditions and wear.
And so you get the worst of both worlds- fussy carb and inscrutable computer. Thing seems to work pretty well, though, most of the time... just heinously inelegant.
t
'89 V6 4dr- '4- Doris'
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6248 MB (Peak: 0.7284 MB) Data Comp: Off Server Time: 2026-06-22 21:15:40 UTC
