how to clean up aluminum wheels?
#524009
11/09/04 10:50 PM
Is there an easy way to clean up the oxidation? on aluminum wheels? I'm trying to decide which to keep between 2 sets of wheels. Thanks.
1985 runner, completely stock(still)
Re: how to clean up aluminum wheels?
[Re: randito]
#524010
11/09/04 11:00 PM
2000 4Runner | 5-speed | E-locker | Tundra/OME 2" lift | Stubbs Sliders | Deckplate/TrueFlow |
[Re: BoostedInline6]
#524011
11/10/04 02:10 AM
Below are some pics of what I did. I bead blasted them and then painted them with the Hammered Rustoleum. Came out very nice. I tried the method mentioned above first but it was very time consuming. Wheels ![[Linked Image]](http://www.yankeetoys.org/87turbo/Images/MVC-016S.JPG)
[Re: randito]
#524012
11/15/04 04:40 AM
Is there an easy way to clean up the oxidation? on aluminum wheels? I'm trying to decide which to keep between 2 sets of wheels. Thanks. Go to a boat dealer and buy the stuff they use to clean the pontoons on a pontoon boat. It`s an acid mix that removes aluminum oxidization. It won`t help you if the factory clearcoat is not completely removed first though. Toughguy <img src="/forums/images/graemlins/coolg.gif" alt="" />
Roads? Where I`m going, I don`t need roads!
[Re: Toughguy]
#524013
11/15/04 03:57 PM
Speedy metal polish with some 0000 or 000 steel wool Mine wre cover with overspray on oxidation, the steel wool works as a nice abrasive without excess scratching
87 toyota 22re-T intercooled with attitude SAS/5.29's/Detroit/LSD/Rear Discs
Summer ride 87 supra turbo, fully built and modified 416rwhp
[Re: Toughguy]
#524014
11/16/04 08:04 AM
Is there an easy way to clean up the oxidation? on aluminum wheels? I'm trying to decide which to keep between 2 sets of wheels. Thanks. Go to a boat dealer and buy the stuff they use to clean the pontoons on a pontoon boat. It`s an acid mix that removes aluminum oxidization. It won`t help you if the factory clearcoat is not completely removed first though. Toughguy <img src="/forums/images/graemlins/coolg.gif" alt="" /> Use Aircraft Paint Remover on clearcoat rims.Be careful read instructions.Then use acid second
88 4x4 22re 86 2wd 1-ton 22re 91 2wd 22re
PHP: 7.4.33 Page Time: 2.384s Queries: 15 (0.004s) Memory: 0.6084 MB (Peak: 0.6782 MB) Data Comp: Off Server Time: 2026-06-13 14:01:55 UTCValid HTML 5 and Valid CSS
