How do I clean my windshield?
#525238
11/12/04 10:00 PM
My windshield on my Tacoma has a smeared look when it rains and the wipers are on. It's dangerous at night with lights reflecting off the windshield. It may be that I got some silicon on it when I wiped the rubber gasket around the windshield with "Son of a Gun Protectant." Or, it may be car wax gets on it when I wipe down the body. I've tried degreaser, alcohol and window cleaner, but those don't work. Any other suggestions?
Re: How do I clean my windshield?
#525239
11/13/04 02:37 AM
Former Admin
Invisible Glass (inside and out) works wonders. Then hit it with RainX. Perfect combination.
#525240
11/13/04 05:05 AM
Try replacing your wipers. If you got solvent on the rubber it will continue to smear everytime you use them. RainX is also a great choice, inside and out.
#525241
11/13/04 04:57 PM
Thanks for the suggestions.
#525242
11/13/04 09:44 PM
Any glass cleaner should help. Rain-X is great, and car wax also does an exceptional job polishing glass. The water beads even better than RainX!
#525243
11/13/04 10:04 PM
My wiper refills seemed to smear like they are worn not that long after I replace them. The white foam type glass cleaner works great. Clean the blades and see how much crap comes off them.
[Re: agroal]
#525244
11/14/04 02:16 AM
clean auto glass with auto glass clean not house window cleaner like windex
when you get the cleaner, find the type that is amonia free or says safe for tinted windows if you have them
after you clean the glass use rainx on it
i just did mine 2 days ago and the day after it rained all day and i never used my wipers once
#525245
11/14/04 05:59 PM
Thanks fellas...I'm going to try out some of your suggestions.
#525246
11/15/04 04:49 PM
Keiller -- I have noticed a similar problem with my windshield -- especially at night in the rain. I use that Meguiars or Eagle One spray-on detailer regularly -- I was blaming it on that. It's great stuff and has allowed me to keep my vehicle very clean without as much work as I used to put into it. BUT -- I think the stuff may run down from the roof and contaminate windshield/wipers (guessing).
--- 02 Taco 4x4, V6, TRD
[Re: wademan]
#525247
11/15/04 07:20 PM
mine normaly smear for the first 20 min im in rain. After that they seem to work fine. it doenst rain too too much here so i think it just has to wipe through a film of dust or somethen. =/
Welding and Fabrication Engineer 2003 taco V6 ext cab sr5 1988 Toyota Pickup V6(totaled)
PHP: 7.4.33 Page Time: 1.613s Queries: 16 (0.004s) Memory: 0.6261 MB (Peak: 0.7262 MB) Data Comp: Off Server Time: 2026-06-21 01:36:07 UTCValid HTML 5 and Valid CSS
